ASUS Q170M2 BIOS Q170M2-SI-1802 CPU Intel® for 6th Generation Core™ i7/Core™ i5/Core™ i3/Pentium®/Celeron® Processors Supports Intel® 14 nm CPU Supports Intel® Turbo Boost Technology 2.0 * The Intel® Turbo Boost Technology 2.0 support depends on the CPU types. * Refer to www.asus.com for CPU support list Chipset Intel® Q170 Memory 4 x DIMM, Max. 64GB, DDR4 2133 MHz Non-ECC, Un-buffered Memory Supports Intel® Extreme Memory Profile (XMP) * Hyper DIMM support is subject to the physical characteristics of individual CPUs. * Refer to www.asus.com for the Memory QVL (Qualified Vendors Lists). * The maximum memory frequency supported varies by processor. * To prevent system instability, either install DDR3L DIMMs or DDR3 DIMMs with voltage lower than 1.5V. Graphic Integrated Graphics Processor- Intel® HD Graphics support Multi-VGA output support : DVI-D/DVI-I/DisplayPort ports - Supports DVI-D with max. resolution 1920 x 1200 @ 60 Hz - Supports DVI-I with max. resolution 1920 x 1200 @ 60 Hz - Supports DisplayPort with max. resolution 4096 x 2304 @ 60 Hz Maximum shared memory of 1024 MB Supports Intel® InTru™ 3D, Quick Sync Video, Clear Video HD Technology, Insider™ Supports up to 3 displays simultaneously Multi-GPU Support Supports AMD Quad-GPU CrossFireX™ Technology Expansion Slots 1 x PCIe 3.0/2.0 x16 (x16 mode) 1 x PCIe 3.0/2.0 x16 (x8 mode) 1 x PCIe 3.0/2.0 x1 1 x PCI 1 x mini-PCIe (half-length) Storage Intel® Q170 chipset : 6 x SATA 6Gb/s port(s), 1 x M.2 Socket 3, with M key, type 2242/2260/2280 storage devices support (both SATA & PCIE mode)* LAN Intel® I219LM, 1 x Gigabit LAN Controller(s) Realtek® RTL8111H, 1 x Gigabit LAN Controller(s) ASUS LAN Guard Audio Realtek® ALC887 7.1-Channel High Definition Audio CODEC *1 - Supports : Jack-detection, Front Panel Jack-retasking USB Ports Intel® Q170 chipset : 10 x USB 3.0/2.0 port(s) (6 at back panel, blue, 4 at mid-board) Intel® Q170 chipset : 2 x USB 2.0/1.1 port(s) (2 at mid-board) Special Features ASUS 5X Protection II : - ASUS LANGuard - 2.5X higher surge tolerance - ASUS Overvoltage Protection - World-class circuit-protecting power design - ASUS DIGI+ VRM - 5 Phase digital power design - ASUS DRAM Overcurrent Protection - Prevents damage from short circuits - ASUS Stainless-Steel Back I/O - 3X corrosion-resistance for greater durability ASUS Exclusive Features : - AI Suite 3 - Ai Charger - Mobo Connect ASUS Quiet Thermal Solution : - ASUS Fan Xpert 2+ ASUS EZ DIY : - ASUS CrashFree BIOS 3 - ASUS EZ Flash 3 - ASUS UEFI BIOS EZ Mode - Push Notice ASUS Q-Design : - ASUS Q-Slot - ASUS Q-DIMM TPM IC Onboard Media Streamer Operating System Support Windows® 10 , 64bit Windows® 8.1 , 64bit Windows® 7 , 32bit/64bit *2 Back I/O Ports 1 x PS/2 keyboard (purple) 1 x PS/2 mouse (green) 1 x DVI-D 1 x DVI-I 1 x DisplayPort 2 x LAN (RJ45) port(s) 6 x USB 3.0 (blue) 3 x Audio jack(s) Internal I/O Ports 1 x MONO out header *3 2 x USB 3.0 connector(s) support(s) additional 4 USB 3.0 port(s) 1 x USB 2.0 connector(s) support(s) additional 2 USB 2.0 port(s) 1 x M.2 Socket 1 with E key, type 2230 Wi-Fi devices support 1 x M.2 Socket 3 with M Key design, type 2242/2260/2280 storage devices support (Supports both SATA & PCIE SSD) 1 x LPT header 2 x COM port(s) connector(s) 6 x SATA 6Gb/s connector(s) 1 x CPU Fan connector(s) (1 x 4 -pin) 2 x Chassis Fan connector(s) (2 x 4 -pin) 1 x 24-pin EATX Power connector(s) 1 x 8-pin ATX 12V Power connector(s) 1 x Front panel audio connector(s) (AAFP) 1 x Internal speaker connector(s) 1 x System panel(s) 1 x Chassis Intrusion connector(s) Accessories User's manual I/O Shield 2 x SATA 6Gb/s cable(s) 2 x M.2 Screw Package 1 x Supporting DVD BIOS 128 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI3.0, WfM2.0, SM BIOS 3.0 ACPI 5.0, Multi-language BIOS, ASUS EZ Flash 3, CrashFree BIOS 3, F6 Qfan Control, F3 My Favorites, Quick Note, Last Modified log, F12 PrintScreen, and ASUS DRAM SPD (Serial Presence Detect) memory information Manageability WfM 2.0, DMI 3.0, WOL by PME, PXE Support Disc Drivers ASUS Utilities ASUS EZ Update Anti-virus software (OEM version) Form Factor uATX Form Factor 9.6 inch x 9.6 inch ( 24.4 cm x 24.4 cm ) Note *: M.2 shares SATA mode with SATA ports. Change this item before installing M.2 SATA devices. *1: Use a chassis with HD audio module in the front panel to support an 8-channel audio output. *2 Please refer to ASUS website and download “Windows® 7 installation guide” and “ASUS EZ installer” to install Windows® 7. *3: Use with amplified speaker is suggested.
