ASUS N3050T BIOS N3050T-SI-0402 CPU Intel® Celeron® Dual-Core N3050 SoC onboard Processors Memory 2 x SO-DIMM, Max. 8GB, DDR3 1600/1066 MHz Non-ECC, Un-buffered Memory *1 Dual Channel Memory Architecture * Refer to www.asus.com for the Memory QVL (Qualified Vendors Lists). Graphic Integrated Graphics Processor Multi-VGA output support : HDMI/RGB/LVDS ports - Supports HDMI with max. resolution 3840 x 2160 @ 30 Hz - Supports LVDS with max. resolution 1920 x 1200 @ 60 Hz - Supports RGB with max. resolution 1920 x 1200 @ 60 Hz Maximum shared memory of 512 MB Supports up to 3 displays simultaneously Expansion Slots 1 x mini-PCIe (full-length) 1 x mini-PCIe (half-length) Storage 2 x SATA 6Gb/s port(s), 1 x mini-SATA 6Gb/s port(s)*2, LAN Realtek® RTL8111H, 1 x Gigabit LAN Controller(s) Audio Realtek® ALC887-VD2 8-Channel High Definition Audio CODEC - Supports : Jack-detection, Front Panel Jack-retasking USB Ports Built-in Controller : 4 x USB 3.0 port(s) (4 at back panel, ) GL852G USB Hub : 5 x USB 2.0 port(s) (5 at mid-board) Special Features ASUS 5X Protection : - ASUS LANGuard - Advanced LAN protection - ASUS Enhanced DRAM Overcurrent Protection - Short circuit damage prevention - ASUS ESD Guards - Enhanced ESD protection - ASUS High-Quality 5K-Hour Solid Capacitors - 2.5x long lifespan with excellent durability - ASUS Stainless Steel Back I/O - 3x more durable corrosion-resistant coating ASUS Exclusive Features : - AI Suite 3 - Ai Charger - USB 3.0 Boost - Mobo Connect ASUS Quiet Thermal Solution : - ASUS Fan Xpert ASUS EZ DIY : - ASUS CrashFree BIOS 3 - ASUS EZ Flash 3 - Push Notice 100% All High-quality Conductive Polymer Capacitors Media Streamer Operating System Support Windows® 10 , 64bit Windows® 8.1 , 64bit Windows® 7 , 64bit Back I/O Ports 1 x D-Sub 1 x HDMI 1 x LAN (RJ45) port(s) 4 x USB 3.0 2 x Audio jack(s) 1 x DC power connector(s) Internal I/O Ports 3 x USB 2.0 connector(s) support(s) additional 5 USB 2.0 port(s) 1 x COM port(s) connector(s) 2 x SATA 6Gb/s connector(s) 1 x SATA power connector(s) 1 x mSATA connector 1 x CPU Fan connector(s) (1 x 4 -pin) 1 x Chassis Fan connector(s) (1 x 4 -pin) 1 x Front panel audio connector(s) (AAFP) 1 x Internal speaker connector(s) 1 x Chassis Intrusion connector(s) 1 x 2-pin internal DC power connector 1 x Stereo speaker connector 1 x DMIC header 1 x LVDS connector(s) 1 x 14-1 pin TPM connector 1 x System panel connector 1 x Display panel backlight power selector 1 x Flat panel display brightness connector 1 x Display panel VCC power selector 1 x LCD panel monitor switch header Accessories User's manual I/O Shield Thin Mini ITX I/O Shield 1 x SATA power cable 2 x SATA 6Gb/s cable(s) 1 x Mini PCIe Screw Package BIOS 64 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.8, ACPI 5.0, Multi-language BIOS, ASUS EZ Flash 3, ASUS CrashFree BIOS 3, My Favorites, Quick Note, Last Modified log, F12 PrintScreen, F3 Shortcut functions and ASUS DRAM SPD (Serial Presence Detect) memory information Manageability WfM 2.0, DMI 2.0, WOL by PME, PXE Support Disc Drivers ASUS Utilities EZ Update Anti-virus software (OEM version) Form Factor Thin Mini ITX Form Factor 6.7 inch x 6.7 inch ( 17 cm x 17 cm ) Note *1 Support both 1.35V DDR3L and 1.5V DDR3 *2 mSATA shares the same slot with the full-length mini-PCIe card. mSATA shares the same bandwidth with SATA6G_2 slot. When a device is installed on the SATA6G_2 slot, the mSATA device is disabled. *DC in connector dimension: 7.4 x 5.1mm, Support both 19V and 12V DC input
