APPLE A1502 emc2875, 2014-15 820-3476-A need BIOS
Discussion in 'BIOS/UEFI' started by bushmann, Jun 17, 2018.
  1. bushmann
    bushmann Well-Known Member
    Dear all.
    Please help me, I need BIOS for Apple probook A1502 EMC 2875 2014-2015 .
    Mainboard number is 820-3475-A .
    I tried using version 2013 downloaded from here, but macbook slow startup and freezes if I install OS.
    info from BIOS file
    MBP111.88Z.0142.B00.1708080655 Copyright (c) 2005-2017 Apple Inc. All rights reserved. Apple ROM Version BIOS ID: MBP111 Built by: root@saumon Date: Tue Aug 8 06:50:20 PDT 2017
    Revision: 142~1 (B&I) Buildcave ID: 0 ROM Version: 0142_B00
    Thanks
    Similar Threads - APPLE A1502 emc2875 Forum Date
    Apple Apple a1502 emc2678 820-3476-A BIOS/UEFI Dec 29, 2014
    Apple Apple MacBook Pro Retina 13' A1502 051-0052 820-3536 J44 MLB-4G Schematics Jul 21, 2014
    APPLE iMac 21.5" A1418 820-01061-A BIOS/UEFI Aug 17, 2019
    Apple SPI J6100 for MacBook , Air Pro 2010-2017 SPI-ROM Cable New 2019 Apple spi Computer Hardware Repair Mar 8, 2019
    APPLE MAC Conversion Discrete to UMA Pls BIOS/UEFI Sep 27, 2018
  4. bushmann
    So, I am try many version from this forum but any not working .
    All freezze if I start installation OS.
    This is original BIOS, but device has been remotely blocked .
    Password has been removed now.
    If now started installation OS, so system wrote this device is bllocked .
    Please you know remove this locked from this BIOS .
    Thanks
    here
  6. bushmann
    Hi .
    this version is MBP111.88Z.0138.B03.1310291227 Copyright (c) 2005-2013
    I testing this version but not working.
    I need version MBP111.88Z.0142.B00.1708080655 Copyright (c) 2005-2017
    Please, you can edit mi file from a blocked device or not.
    Another version does not work.
    I tested all files for this model, from this forum.
    same BIOS, only same motherboatd code. :fou: (fou)
  8. bushmann
    I have only one motherboard 820-3475-A.
    Apple used this model in production year mid2014 - mid2015.
    This information I found on internet .
    This motherboard have BIOS version MBP111.88Z.0142.B00.1708080655 .
    I tested many versions with 88Z.0138 Bxx on this motherbaoard 820-3475-A but not working .
    All version with 88Z.0138 Bxx freezes on the first screen, If I starting instalation OS from USB.
    After freezes on first screen not any more sound and reactions.
    Install on USB disk is 100% OK.
    If I used internet recovery, have same problem .
    I found on this forum only one version 88Z.0142 with password .
    When, I removed password from this version, so I'am used.
    After I running OS installation from USB drive, first screen is freeze, but on background system says "please select installation language" .
    If I using keys up and down system change language.
    But I don't see this screen, I see only first screen APPLE.
    System not komplet freeze only screen or GPU not inicialing.
    I don't know, where is problem.
    I have this problem before on another model .
    I had to use the same BIOS but with change of content.
    Any other BIOS files have same problem.
    I have one guys, what is needed changed on original BIOS file, but want moneys.
    So it I try on this forum.
  9. MrDarksTom
    MrDarksTom New Member
    POR FAVOR PUEDEN QUITAR EL PASSWORD DE ESTA MACBOOK A1502 EMC 2875
  11. modinside
    modinside New Member
    please unlock this efi when installer load show a screen asking system password
