HP ProBook 430 G3 - DA0X61MB6G0
Discussion in 'BIOS/UEFI' started by technical, Jun 14, 2016.
    you want lock account ?
    inbox now :nrg:
  2. Adesh
    Adesh Well-Known Member
    Need bios DA0X8BMB6F0 REV F
  4. Adesh
  5. Bios & Esquemas
    Bios & Esquemas Well-Known Member
    BIOS I3 PLEASE I5 OR I7 NO WORKING 430 G3 COREI 3 SR2EU PLEASE
    send bios old i check
  7. Bios & Esquemas
    I DO NOT HAVE THE IDPRODUCT OR SERIAL LABEL DELETED AS I LOOK FOR IN THE BACKUP BIOS
    want i help you need provided right info, and the above bios certificate does not work.
  9. Bios & Esquemas
    [QUOTE = "Bios & Esquemas, post: 110217, miembro: 97979"] NO TENGO EL IDPRODUCTO O LA ETIQUETA DE SERIE BORRADO COMO BUSCO EN LA BIOS DE RESPALDO [/ QUOTE]
    [QUOTE = "Bios & Esquemas, post: 110217, member: 97979"] NO TENGO EL IDPRODUCTO O LA ETIQUETA DE SERIE BORRADO COMO BUSCO EN LA BIOS DE RESPALDO [/ QUOTE]
  10. Hasanrony145
    Hasanrony145 New Member
    plz help
    da0x61mb6g0 rev: g
    model: x61
    bios plz
    on top Available
  12. Hasanrony145
    this bios not work
  13. Hasanrony145
    this bios is origanal
    old bios error what ?
  15. Hasanrony145
    bios we provided same problem or other
    and how you know not work ?
    can laptop have problem other
  17. laptech
    laptech Well-Known Member
    440 G3 old bios backup file 2 long 2 short beep plz build bios
    try one BIOS new and compare result
  19. laptech
    That's because you only download BIOS clear me. Note not always use clear me but only work in some cases
    try file this
    laptech likes this.
Similar Threads - ProBook DA0X61MB6G0 Forum Date
