HP ProBook 450 G3 DAX63CMB6C0 BIOS X63C
Discussion in 'BIOS/UEFI' started by technical, Jan 20, 2017.
    here is problem DMI, what happened before?
    You have saved the original bios of the machine?
  2. synapsea
    synapsea Well-Known Member
    before no video here is my dump
  4. synapsea
  5. laptopuri
    laptopuri Well-Known Member
    This is my bios file for hp 470 g3 with motherboard dax63cmb6c0 rev c model x63c. My bios frozzen when to boot from hdd,ssd, dvd or usb(screen goes black after hp log). All the bios from ubove no good and if i put a bios for 450 g3 with the same motherboard i dont have m.2 sata port available anymore. Please try to clearn me my bios. Thank you
    try this
    HP ProBook 450 G3 DAX63CMB6C0 REVC
  7. synapsea
    i just tried this dump NO DISPLAY cpaslock blink 5 times after fan stay in turbo and no display
    check hardware.
  9. aclaptop
    aclaptop Well-Known Member
    [QUOTE="ThienBui]
    clear me giúp e
    clear me 450g3.bin.bin
  11. laptopuri
    ThienBui your bios is not good my hardware is good and whith your bios no video. I need bios for 470 g3 not 450 g3(450 g3 dont support m.2 sata ssd)
    old bios have display or not ?
  13. laptopuri
    yes old bios have video on but when i m trying to boot the image freez
    hp 450 G3 DAX63CMB6C0 REVC
    DAX63CMB6C0 REV C .
  15. tuanhtvn
    tuanhtvn Well-Known Member
    clear me.
  17. 40ifix
    40ifix Well-Known Member
    please repair this bios
    problem no signal
    fan high speed
    try bios clear me above and compare results before.
  19. 40ifix
    i had tried all power ok no signal >>>
    try file this, If all the same problem you need to check the hardware
Similar Threads - ProBook DAX63CMB6C0 BIOS Forum Date
