MacBook Pro 13" Touch Bar 2018 820-00850
Discussion in 'BIOS/UEFI' started by technical, Aug 20, 2018.
    MacBook Pro 13" Touch Bar (A1989)
    820-00850-07
    820-00850-A
    820-00850-B
    820-00850.
  3. Atinder Saini
    Atinder Saini Well-Known Member
    Schematics for sale?
  4. 01ifix
  5. Atinder Saini
    UPDATE:Someone said that there is no sam connector for mid 2018 and 2018 do not have efi IC that there is new security. Anyone with available schematics for newer 2018 models?
    sam connector missing. im thinking soldering sam connector because it looks like pinout is there.
    #4 Atinder Saini, Sep 1, 2018
  6. therealjayvi
    therealjayvi Well-Known Member
    Here is a more detailed picture of the chip in the picture above, maybe somebody else will have better luck in finding a data sheet or something. I've tried contacting both Renesas as well as Intersil directly to locate information about the chip and neither have any clue about what it is.
    1f1493eebd97ab73be0f52f175f3079d.
  7. therealjayvi
    I can confirm that the hirose connector does NOT fit on the pins between the T2 and the CPU. If you look elsewhere you will find that this plug is found in multiple places throughout the board, though between the T2 and the CPU is the only place where the pins are covered up. Scratching back the traces and tinning the pads reveals that the pins have a smaller than 0.4mm pitch. After doing some basic math, I estimate the pitch needed to be about 0.27mm, and at this time there is no sam connector available on digikey or mouser. I do not have a steady hand enough needed to solder micro wires to the pads to test for connectivity, though maybe somebody else will.
  8. Atinder Saini
    I solder wires but no connection. We would need schematics but even that doesn't mean it would allow write. If schematics are there I could solder but issues is layout/data sheet.
    zimri likes this.
  9. therealjayvi
    I'm confident that I could find at least more info than we have now with a successful soldering to the pads. My hands are tied steady enough nor do I have the proper equipment to be able to attach wires to each of the pads without bridging anything. It may not lead to anything important, but anything is better than nothing .
    On a side note, I've heard from multiple sources (questionable credibility) that connectivity to the board may be possible through thunderbolt ports somehow. One source even said specifically the "back-right port" is used to probe the board. I have yet to confirm or deny this but my be worth looking into.
  10. 18ifix
    18ifix Moderator
    schematic !!!!
  11. therealjayvi
    You have?
  12. 18ifix
    18ifix Moderator
    what you need .
  13. 18ifix
    18ifix Moderator
    ok T2 chip is just controller .. remeber ...!!!!!! hhhh full securty ... applezzzzzzzzzz what you want applezzzzzzzzzzzzzzzz
  14. 18ifix
    18ifix Moderator
    see this picture .....
      836.1 KB
      5
  15. racchid
    racchid Well-Known Member
    A1990 (EMC 3215)
    can you help me for that , unlock bios?!
    backup send i file bios.
  17. racchid
    dindn't find bios ship!!!!!
  18. 01ifix
    model 2018 have special chip security so cant remove efi on this moment no solution friend
  19. racchid
    thank you
  20. dam1inc
    dam1inc New Member
    no schematics available yet?
    Sent from my SM-G955U using Tapatalk
    current Unavailable schematic
