HP-Compaq HP elitebook 840 g1 6050A2560201-MB-A03
Discussion in 'BIOS/UEFI' started by technical, Jul 7, 2015.
  1. 01ifix
    here
  2. alexandre onisaki
    alexandre onisaki Well-Known Member
    Thanks for the answer....
    but the bios is giving error .....
    sku number
    is there any way to remove this error?
  3. 01ifix
    bios you send is back up from laptop ? or you download here the bios ?
  4. alexandre onisaki
    I send again... this backup file...
    sorry
  6. alexandre onisaki
    Hi thien
    I already bought this solution .... but when I use hxd and edito ...
    gets sku error
    it will automatically recover after a few reboots
  8. Khalidna
    Khalidna Well-Known Member
    your bios have domain password
    i send old bios working fine but late display can you check plzzzzz
  10. mohamed1917
    mohamed1917 Well-Known Member
    can you clear this
    clear me
  12. tuanhtvn
    tuanhtvn Well-Known Member
    Nhờ ad fix hộ 840 g1 bị pass. Thanks
    840 g1_unlock.bin
  14. tuanhtvn
    file này ko bật đc nguồn ad ạ
    file của bạn gửi mà test lại xem con chạy ko.
  16. tuanhtvn
    Mình nạp file gốc đó vẫn lên nhưng bị pass bios đó
    unlock.bin
  18. cumelsk
    cumelsk Well-Known Member
    Elitebook 840 G1 MB-A02 ClearME BIOS tested OK
    NO ERROR MACHINE IS IN COMMITED STATE
  19. SURENDER KASANA
    SURENDER KASANA Well-Known Member
    clear me and send
Similar Threads - elitebook 6050A2560201 Forum Date
hp elitebook 840 g5 BIOS/UEFI Feb 3, 2021
HP EliteBook 745 G6 BIOS/UEFI Aug 1, 2019
HP EliteBook 755 G5 TRYPTICO 6050A2945701-MB-A01 (A1) BIOS/UEFI Aug 1, 2019
HP EliteBook 1050 G1 BIOS BIOS/UEFI Jun 28, 2019
HP EliteBook x360 1040 G6 BIOS BIOS/UEFI Jun 28, 2019
