Toshiba Toshiba Setellite L500 Compal LA-4982P
Discussion in 'Schematics' started by technical, May 11, 2014.
    Toshiba Setellite L500 (Compal LA-4982P)
    Similar Threads - Toshiba Setellite L500 Forum Date
    Toshiba Toshiba Setellite L500 Compal LA-4982P Schematics May 11, 2014
    toshiba 32pb200E startup problem Schematics Apr 7, 2022
    Toshiba MB: LA - B302P / Rev:1.0 BIOS/UEFI Mar 31, 2020
    TV Toshiba 26W330D ELECTRONIC DEVICE Aug 22, 2019
    TV Toshiba 27WLT56B ELECTRONIC DEVICE Aug 22, 2019
    Toshiba L500_LA-4982P OK
    BIOS Toshiba Satellite A500/L500
    Model: PSLWSE, PSLWTE, PSLS9E, PSAR9E, PSLJHE, PSLJFE, PSLS6E, PSLWKE, PSLWJE, PSAR6E
    Plate number: KSWAA LA-4982P
    Fit Model:
    Satellite A500, Satellite L500, Satellite L505, Satellite L550, Satellite Pro L550, Satellite L555
  5. mahmoud2020
    mahmoud2020 New Member
    thanks a lot
  6. sunsoft
    sunsoft New Member
  7. 07ifix
    07ifix Moderator
    i need a board view plz
    la-4982p
  8. gabritex
    gabritex New Member
    Triyng to flash this bios MX 25L1605DM2I, select on flyPRO MX25L1605D but says Device ID error...!!! ???
    check tool Programming
    current Unavailable
  11. macabi170
    macabi170 Well-Known Member
    LA-4982P MXM to uma? as it has GM45 NorthBridge
    you need i help what ?
  13. macabi170
    any way to convert the discrete GPU to UMA?
    unavailable
