lenovo yoga 500 not charging
Discussion in 'Computer Hardware Repair' started by hgzy ahmd, May 14, 2018.
  1. hgzy ahmd
    hgzy ahmd Well-Known Member
    this problem repeated in this model
    I replace battery but not fix the problem
    replace charging ic bq24780 but not fix it
    I flashed main bios not fix it
    software like the Power Management not fix it
    all measurable components are good ( mosfets - resistors - ... )
    I have two notebooks with the same issue
    please what's yours suggestions?
      393.2 KB
      2
      349.1 KB
      2
      282 KB
      2
      137.1 KB
      2
    Similar Threads - lenovo yoga charging Forum Date
    BIOS PC lenovo yoga 310s-11iap BIOS/UEFI Mar 5, 2020
    Lenovo Yoga C930-13IKB EYG70 NM-B741 ARIEL-SOVP REV: 1.1 LENOVO Jul 27, 2019
    Lenovo Yoga 920 LCFC NM-B291 ( DYG60 ) Computer Hardware Repair Jun 17, 2019
    Yoga S730-13IWL Laptop (Lenovo) BIOS BIOS/UEFI May 28, 2019
    Lenovo ThinkPad Yoga 370 - Type 20JH MB CIZS3 LA-E292P BIOS/UEFI Apr 7, 2019
  3. 01ifix
    nuvoton have 3.3v ?
  4. hgzy ahmd
    yes dear there is 3.3 charging id on RN2403
      311.6 KB
      3
  5. hgzy ahmd
    NOTE:
    notebook is working will , and working on charged battery ,
    I replace io and fleshed bios over windows but the same ,not charging :(
      262.4 KB
      2
      232.2 KB
      2
  6. 01ifix
    with schematic can check all signals and maybe can fix it
  7. hgzy ahmd
    here is schematic for bq24780
    http://www.ti.com/lit/pdf/tidrh84
    but i dont found schematic for this model
  8. zmogienas
    zmogienas Well-Known Member
    Hello! Found the solution? :)
  9. soupapowa
    soupapowa New Member
    Hello,
    Your problem is complicated...
    I think you have to find components (MOSFET, Capacitor) nearly the battery.
    And try to check that, maybe one component is broken.
  10. MOBOKAP
    MOBOKAP Well-Known Member
    I have found the solution . After PD4403 have an resistor 10 ohm . my resistor was 560 OHM. and BQ 24780 dont have 20V VCC in pin 28 .
      349.4 KB
      3
  11. 01ifix
    thanks for share knowledge
  12. gligurski
    gligurski New Member
    Beautiful and elegant solution. Thank You very much. Worked like a charm straight away. Found the resistor, mine was around 460 Ohm, replaced it with 10 Ohm, charging started immediately. Thank You again.
  13. Deppe92
    Deppe92 Well-Known Member
    You Sir, won the Internet! Keep up the good work!
    Mine had 7k Ohm
  14. xiaocao1021
    xiaocao1021 New Member
