Quanta 0P2 0P2A
Discussion in 'Schematics' started by technical, Sep 28, 2017.
    0P2 Boardview
    NFL-C 14" AMD SR FT4 DIS/UMA Block Diagram
    Rams 0P2/0P2A Schematics
    DA00P2MB6D0
    BIOS DA00P2MB6D0 REV D
    0P2.
    Similar Threads - Quanta 0P2A Forum Date
    DELL M6400 QUANTA XM1 Schematics Jul 8, 2019
    Quanta YORP ZAK ZAN Schematics Schematics Apr 23, 2019
    Quanta ZAD r2A Schematics Apr 23, 2019
    HP14-bw053au DA00P2MB6D0
    BIOS 0P2
  4. rossmery gonzales
    rossmery gonzales Well-Known Member
    BUENAS NOCHES, TENGO UN PROBLEMA CON ESTA COMPUTADORA PORTÁTIL DA00P2MB6D0 REV D YA LE GRABE LA BIOS CON LA INFORMACIÓN QUE ESTA AQUÍ Y AUN ASI NO DA LA IMAGEN PERO SI CALIENTA EL MICROPROCESADOR? ALGUNA SUGERENCIA ??
    try one bios new above before.
  6. rudi suhartanto
    rudi suhartanto Well-Known Member
    boss, the bios file that you sent died and my bios turned on just didn't appear. can you send the bios file again normally
    one new update on top.
  8. pampanga chapter
    pampanga chapter Well-Known Member
    Pls clean this bios with graphics
    AMD not use Me Region
    pampanga chapter likes this.
  10. Bios & Esquemas
    Bios & Esquemas Well-Known Member
    [QUOTE = "ThienBui, post: 113313, miembro: 6"] AMD no me utiliza la Región [/ QUOTE] porfavor Tienes el BIOS EC de esa placa?
    send i file old.
  12. Bios & Esquemas
    [QUOTE = "ThienBui, post: 119161, miembro: 6"] enviar archivo i antiguo. [/ QUOTE]
    file this white no have data. you read from KB9027B ?
    currently i don't see this IO programming information
