A1708 EMC3164 BIOS 820-00840-A
Discussion in 'BIOS/UEFI' started by technical, Nov 25, 2017.
    A1708 ECM3154 820-00840-A_Clear me.bin
  2. rasta24
    rasta24 Well-Known Member
  3. rasta24
    tengo problemas en el equipo no detecta disco duro
    What has happened before ?
  5. rasta24
    [QUOTE = "ThienBui, post: 90611, miembro: 6"] ¿Qué pasó antes? [/ QUOTE]
    lo puse y enciende y da video pero no detecta disco duro
    You need check all and repair.
  7. rasta24
    [QUOTE = "ThienBui, publicación: 73657, miembro: 6"] MacBook Pro Retina 13,3 A1708 EMC3164, mediados de 2017
    BIOS 820-00840-A [/ QUOTE]
    puse este y si detecta el disco y se puede formatear y se instala el sistema pero cuando quiere iniciar sale letrero
    try test hardware
    https://vinafix.com/threads/how-to-use-apple-hardware-test-to-diagnose-mac-problems.23217/
    How to Use Apple Hardware Test to Diagnose Mac Problems
    How to Use Apple Hardware Test to Diagnose Mac Problems One of the definitive ways for an average user to determine if their Mac has a hardware problem is to run Apple Hardware Test or Apple...
    vinafix.com
  9. Jitendrakashyap
    Jitendrakashyap Well-Known Member
    your bios icloud password please clear the password
  10. 01ifix
    upload your dump i help you clear password friend
    FINEAS likes this.
  11. Jitendrakashyap
    please change chinesse language also convert into in english language please...
    It's funny how all Macbooks are multilingual, You can convert in Mac OS....
  13. Jitendrakashyap
    ok...unpass bios
  14. 01ifix
  15. Jitendrakashyap
    please change chinese language in to english
  17. nerdavailable
    nerdavailable New Member
    WRONG PDF!
    Why you guys always do that? That is not the first time.
    problem what ?
  19. b4tech
    b4tech Well-Known Member
    power on no dislpay (no boot sound ,The fan is rpm very fast)
    chk this file Ok or what ? plz
    Programming bios clear me above.
Similar Threads - A1708 EMC3164 BIOS Forum Date
A1708 820-00480-A BIOS/UEFI Mar 12, 2019
Apple Macbook A1708 display problem Computer Hardware Repair Jun 10, 2018
help please a efi dump 820-00840-A i5 2.3ghz A1708 (EMC 3164) BIOS/UEFI Feb 17, 2018
Apple Change Serial A1708 Board Number: 820-00875-a BIOS/UEFI Nov 5, 2017
MacBook Pro 13" A1708 Late 2016 820-00875-01 BIOS 820-00875-a BIOS/UEFI Nov 2, 2016
