Sony QUANTA HK5 HK6 sony mbx-269 SVE151C11T
Discussion in 'Schematics' started by technical, Jan 4, 2014.
  1. eplanet
    eplanet Well-Known Member
    can you give me .brd reader setup
  2. lapcarecenter
    lapcarecenter Well-Known Member
    sir, mbx-269 is auto off every 35 second....p-ls help anybody...
    i changed u r all bios..but no change..
    #43 lapcarecenter, Aug 6, 2018
    any repair or replace ?
  4. lapcarecenter
    no sir...off in 55 secod..any input pls.. any resistor value change like mbx 266.....
    #45 lapcarecenter, Aug 8, 2018
    check hardware, MBX-266 is Discrete change UMA, not repair you need try one BIOS new or check hardware.
  6. ajamin.ali
    ajamin.ali Well-Known Member
    laptop shutdown in 30 min
    main mbx-268 uma
    30min need check hardware.
  8. ajamin.ali
    all part CPU RAM HDD and SJTNV Chip CHANGED
    what happened before? You tried the other BIOSes above ?
  10. Ajaymatrix
    Ajaymatrix New Member
    SONY HK6 MBX-268 PROBLEM IS DATE TIME SAVE CORRECTLY BUT OTHER BIOS SETTINGS ARE CAN'T SAVE .. EVERY TIME GOES DEFAULT WHEN RESTART. BUT DATE TIME RUNNING OK.
    I'm not sure I understand the problem.
    Try another bios....
  12. Ajaymatrix
    Already two three bios downloads from different websites but issue not resolve..
    New motherboard have same issue ... In bios page Me version shows Unknown...
  13. sudarsanankumar
    sudarsanankumar Well-Known Member
    how to convert DIS To UMA da0hk5mb6fo rev f DIS To UMA MBX-269
    pls help
Similar Threads - QUANTA sony SVE151C11T Forum Date
Sony SVF15N1I4RS Quanta FI3 BIOS/UEFI Sep 5, 2016
Sony bios sony mbx-216 quanta gd3 BIOS/UEFI Nov 3, 2015
Sony Sony Vaio Flip 14N SVF14N Quanta FI2 Schematics Jun 22, 2015
Sony SONY VPCEF34FX Quanta NE8 Schematics Apr 30, 2015
Sony Sony svf15AA1MT Quanta GD5 DAOGD6MB8E0 DA0GD6MB8E0 GD6 Schematics Dec 4, 2014
