ASUS ROG GL502VM (7th Gen Intel Core) Intel® HM175 Express Chipset (#Kabylake) Processor Intel® Core™ i7 7700HQ Processor, Intel® Core™ i5 7300HQ Processor, Operating System Windows 10 Home Windows 10 Pro - ASUS recommends Windows 10 Pro. Chipset Intel® HM175 Express Chipset Memory 8 GB DDR4 2400MHz SDRAM Onboard Memory, 1 x SO-DIMM socket , up to 16 GB SDRAM Display 15.6" (16:9) LED backlit FHD (1920x1200) 60Hz Anti-Glare Panel with 72% NTSC with 178˚ wide-viewing angle display with G-Sync 15.6" (16:9) LED backlit FHD (1920x1080) 120Hz Anti-Glare Panel with 72% NTSC with 178˚ wide-viewing angle display with G-Sync 15.6" (16:9) LED backlit UHD (3840x2160) 60Hz Anti-Glare Panel with 72% NTSC with 178˚ wide-viewing angle display with G-Sync Graphic NVIDIA GeForce GTX 1060 , with 3GB/6GB GDDR5 VRAM Storage Hard Drives: 1TB 5400RPM SATA HDD 1TB 7200RPM SATA HDD 2TB 5400RPM SATA HDD Solid State Drives: 128GB/256GB/512GB SATA3 SSD Solid State Drives: 128GB/256GB/512GB PCIE Gen3X4 SSD Keyboard Illuminated Chiclet Keyboard Card Reader Multi-format card reader (SDHC/SDXC/MMC) WebCam HD Web Camera Networking Wi-Fi Integrated 802.11b/g/n Integrated 802.11 AC 10/100/1000 Base T Bluetooth Built-in Bluetooth V4.1 Interface 1 x Microphone-in/Headphone-out jack 1 x Type C USB3.1 (GEN2) Thunderbolt 3 x Type A USB3.0 (USB3.1 GEN1) 1 x RJ45 LAN Jack for LAN insert 1 x HDMI 1 x mini Display Port 1X AC adapter plug Audio Support Windows 10 Cortana with Voice ASUS SonicMaster Technology Battery 4 Cells 64 Whrs Battery Power Adapter Plug Type :ø5.5 (mm) Output : 19.5 V DC, A, 180 W Input : 100 -240 V AC, 50/60 Hz universal Dimensions Tablet: 390 x 266 x 23.5 mm (WxDxH) Weight 2.2 kg with Battery
the bios you send does not working properly on this bios version machines does not power on now clear the attached bios
BIOS above you send not for me, power not on problem not is Me Region. try one BIOS new or check hardware.
the bios I have attached in this message is ok for our machine but there is one issue with this bios, by installing this bios on our machine turned on but does not gave display so please clear this bios and please send me as soon as possible.
Hey I think I have a bad bios on l my laptop i just order the bios flasher and the clip and going to download this when it gets here but I am having trouble identifying what chip the bios is in can you point me in the right direction
i have install first bios gl502vm rev2.1 dis.bin i have an issue with display driver did not install .. i was try many time but failed i need gl502vmk rev 2.1 ok bios....
Hi ThienBui. I have the same problem with Zeeshan in the post above... My motherboard GL502VMK before started without image; after reprogramming the BIOS the laptop returned to display image but when I check the GTX 1060 graphics in the device manager it is not present. If I enable the option to see hidden devices it appears as watermark, but even trying to reinstall the driver it does not become active. Can you help me with this problem? Thanks in advance. Best regards.
