Dell DELL E7240 LA-9431P
Discussion in 'BIOS/UEFI' started by technical, Feb 10, 2015.
  1. Ciprian Baroncea
    Ciprian Baroncea New Member
    Hello when i program the bios i need to chose the correct name. is there any difference ?
  2. Ciprian Baroncea
    What programmer do you use ? Can you give a software that has a full list of devices and works with sofi sp8-a
    I do not understand what you encounter errors ?
    I use TL866 and Xeltek SuperPro 610P
  4. Ciprian Baroncea
    I have problems ..because if you can see the picture .. i`m missing some details of my chip. According to the data sheet ..i have the chip : W25X10CLSNIG _SO8, but when i connect to my device ..as you can see in the picture i`m missing the SNIG _SO8, and to be honest i don`t know if it counts or not. But it does flash it and seems to be properly programmed ...but still doesn`t work :).
    in photo i see W25Q64xx....
    You need find chip W25X10CLxxx...
    two completely different chip, you need to find the right chips salary space or Programming your machine does not support chip this.
  6. hyoucef72
    hyoucef72 Well-Known Member
    Hi
    I have another variant of Latitude E7240 please clear the bios
    Latitude E7240 U1 25Q64_Vina.bin
    Repair ME, Universal Edition
  8. bioshunger
    bioshunger Well-Known Member
    Thanks buddy ... your bios work for my job .. i had also done my job with password problem
    photo_2017-01-16_17-34-13.
    duongddt and technical like this.
    E7240-La-9431P-OK-son-3107_ME.BIN
    Clear me
  10. 09ifix
    09ifix Moderator
    LA-9431P BIOS PASSWORD PLEASE UNLOCK I SEND BIOS FILE
    I think password not in file BIOS, yo can try one BIOS above and check..
  12. raileanu
    raileanu Well-Known Member
    I already upload a while ago and unlocked working bios for your model
  13. khawar
    khawar Well-Known Member
    hello. there is an issue ,the bios is ok but 15 to 20 seconds late display
  15. kythuathobi
    kythuathobi Well-Known Member
    a clearme giup e file này lên chậm ạ
  16. CICTECCH
    CICTECCH Well-Known Member
    Please I need board view for this board VAZ50 LA-9431P
    Unavailable bv
  18. Babatunde E Olugbemi
    Babatunde E Olugbemi Well-Known Member
    hi,i have dell latitude e7240,motherboard number:vaz50 la-9431p rev:1.0 bios that does not see harddrive(ssd) or any flash drive.Please help work on the original bios dump.
    try one bios new above before.
  20. praveshkundaliya
    praveshkundaliya Well-Known Member
    DELL E7240 LA-9431P
    need clean me
Similar Threads - DELL E7240 9431P Forum Date
Thảo luận Dump Bios with a test clip - Dell latitude E7240 Computer Hardware Repair Nov 17, 2016
Dell Latitude E7240X Ultrabook BIOS/UEFI Jun 27, 2016
dell e7240 bios BIOS/UEFI Aug 25, 2015
