Ideapad 500-15ISK - LA-C851P
Discussion in 'BIOS/UEFI' started by technical, Oct 4, 2016.
  2. ajamin.ali
    ajamin.ali Well-Known Member
    I NEED BOARD VIEW
  3. ajamin.ali
    I HAVE LA-C581P START UT HAS 0.02 A WITH POWER SUPPLY
    model this no have BV.
  5. 01ifix
  6. ChetanSethi
    ChetanSethi Well-Known Member
    LA-C851P CLER ME BIOS WANT
    LA-C851P rev 1.0_Clear me.BIN
  8. 08ifix
    08ifix Moderator
    LA-C851P WHAT IS IC NUMBER PUI3 ?
  9. jafar110
    jafar110 New Member
  10. jafar110
    jafar110 New Member
    I have the same problem
    same problem, Please check hardware.
  12. vu hai duy
    vu hai duy Well-Known Member
    nho ad remove pass giup
    Nạp novoton đi bạn
  14. 13ifix
    13ifix Moderator
    can you send me schematic if you dont have then send me motherboard images bcoz some component missing in my m.b..
    Lenovo Idea Pad 500-15ISK LA-C851P AIWZ2 AIWZ3 REV 1.0 2015-07-14 DISCRETE
  16. 02ifix
    lenovo yoga 260
    need AIZS1 LA-C581p
    rev 1.0
    bios please !!
  17. 02ifix
    found on another thread (the search on your site is kind not funcioning well , i had to search for it a few times until more results show up !!!
    bios above not right ?
    Reason ?
  19. 02ifix
    well since there is a big mess here sometimes , that why i asked for the correct chassi :) but if you say this one above work for the yoga260 , i'll try !!
  20. 02ifix
    and also another biggggg important thing , that you usual like sending other for non working bios ... my board has a 16mb and not a 8mb bios ! :) thk you for you patience !!!
Similar Threads - Ideapad 15ISK C851P Forum Date
Y700 Touch-15ISK Laptop (ideapad) LENOVO Aug 27, 2018
510-15ISK Laptop (ideapad) BIOS LENOVO Aug 9, 2018
310 Touch-15ISK Laptop (ideapad) BIOS LENOVO Aug 8, 2018
310-15ISK Laptop (ideapad) BIOS LENOVO Aug 8, 2018
ideapad 110-14ISK, 110-15ISK BIOS LENOVO Aug 8, 2018
