Toshiba Toshiba z830-11m atmel password removal
Discussion in 'BIOS/UEFI' started by yasar, Apr 21, 2018.
  1. yasar
    yasar New Member
    not password in bios file
    password atmel chip
    help me
    Similar Threads - Toshiba z830 atmel Forum Date
    Toshiba Toshiba Z830-11F MB: FALZSY1 A3162A BIOS/UEFI Jun 27, 2015
    Toshiba Bios Toshiba Satellite Z830 A2S BIOS/UEFI Jan 11, 2014
    toshiba 32pb200E startup problem Schematics Apr 7, 2022
    Toshiba MB: LA - B302P / Rev:1.0 BIOS/UEFI Mar 31, 2020
    TV Toshiba 26W330D ELECTRONIC DEVICE Aug 22, 2019
    send i part number and motherboard code ?
  4. yasar
    yasar New Member
    Portege Z830-11M
    PT224E-01V01ETE
    FALZSY1 A3162A
    i not have file bios above, but i think model this password in i/o MEC SMSC.
  6. yasar
    yasar New Member
    yes i wrote bios
    but it did not improve
    atmel chip available
    password is on
    you try remove chip atmel out to motherboard and try, i want know motherboars after work or no.
  8. 01ifix
    schema available ?
  10. 01ifix
    how can read sms mec on this motherboard ?
    or not possible at this time ?
  11. yasar
    yasar New Member
    hi
    removed atmel
    the password is exactly the same
    Atmel is not important
    I wrote 4 different bios
    Yes, i know. i say above password in i/o SMSC you need Programming it.
  13. yasar
    yasar New Member
    changing i / o smsc does it work ?
  14. 18ifix
    18ifix Moderator
    PASSWOD IS NOT ON THE ATML ... IS ON MEC 1618
  15. 01ifix
    hi @cifam you have jtag configuration for read this mec
    i have svod and rt809h programmers
    regards
    BOICU CONSTANTIN likes this.
  16. effektiveddd
    effektiveddd Well-Known Member
  17. mjalil2015
    mjalil2015 New Member
    you need diagram for SMC wires pinout read the smc delete password with hex or rewrite with a new bin file clear but the problem the diagram for this mainboard not avaible
