Toshiba satellite L55Dt-B5175SM PSKUAU DA0BL0MB8F0 REV F
Discussion in 'BIOS/UEFI' started by 01ifix, Apr 26, 2017.
  1. 01ifix
    Similar Threads - satellite L55Dt B5175SM Forum Date
    Satellite L55DT-B5175SM - BL0 BIOS/UEFI Apr 26, 2017
    Toshiba Satellite P855-S5200 P850-S5200 BIOS BIOS/UEFI Jul 18, 2019
    Satellite A305-S6829 (PSAG0U/PSAG4U) BIOS BIOS/UEFI May 30, 2019
    SATELLİTE C55-A-14H PSCGAE-01R00ETE BIOS/UEFI Apr 11, 2019
    satellite radius l40dw-c esac(l) mb rev 2.1a BIOS/UEFI Apr 2, 2019
    01ifix likes this.
  4. MissAircraft
    MissAircraft SUPER VIP
    Hi, I have
    DA0BL0MB8F0 rev F but it has backlight problem. Is there any way somebody without schematic to help how to resolve the issue? I know it used to be Nuvoton the backlight controller but in old models so i dont know if its still the same on new ones
    Try Programming one bios new before..
  6. 03ifix
    Backlight is not a problem bios.
  7. 03ifix
    Check 3.3v voltage led have if not check led connector pin 5 and pin 6 show(3.3v) have or not?
  8. 01ifix
    if AMD platfomr check also GPU and ic near the lvds connector
  9. MissAircraft
    Yes 5 and 6 pins have 3.3 volt. i am wondering which pins control the backlight voltage so i can bypass it and wire another 3.3 voltage to give the required voltage for the backlight to come on. it use npce985la0dx which control the backlight voltage i believe but there should be some extra controller before it reach the LCD connector. The connector is 30 pins so i couldnt find any similar toshiba diagram which will have npce985la0dx as power controller and lcd connector to be 30 pins instead of 40. Any more ideas would be helpful
  10. MissAircraft
    Its AMD but what do you want me to check with GPU and which lvds IC you mean? Be more specific if you want to help or know where to look...
  11. MissAircraft
    The thing is that mainboard lcvds connector is 30 pins but the lcd cable connect to screen with 40 pins so if we knew on the screen pin which of the 40 pins the backlight power pin is then i could wire it from there or check where it beeps on the board
  12. 03ifix
    Check near connector (fuse) and 0 ohm resistor.
  13. MissAircraft
    So after the backlight came by itself the keyboard stop responding so i believe the nuvoton was the issue from the beginning . I replaced the nuvoton IC and all worked fine
