Lenovo 300S LT41 SKL 14292-1
Discussion in 'BIOS/UEFI' started by technical, Dec 30, 2015.
  1. nacres
    nacres Well-Known Member
    Workingggg ^^ thanks you brother.
  2. 08ifix
    08ifix Moderator
    Lenovo Yoga 500-14IHW LT41 MB 14217-1M 448.03N03.001M bios needed
  4. umasankar sahu
    umasankar sahu Well-Known Member
  5. 09ifix
    09ifix Moderator
    schematic ??
    current Unavailable
  7. 09ifix
    09ifix Moderator
    lenovo flex 3 clearme bios plz upload
    what?
  10. macabi170
    macabi170 Well-Known Member
    this is because this bios has more than 16MB, it has additional 768 Byte, which probably has important data on it. when i took a dump without the extra area and programmed to another chip, on the same laptop. with the old chip laptop turns on without screen, but with the new chip. does not turn on at all.
    when I took the new dump with the extra 768 bytes, the laptop turned on without screen, same as with the old chip. can someone upload a good dump with the extra area? thanks
    send old bios I check.
  12. macabi170
    thanks
    No difference
    Add 768 bytes because of your backup tool. ( There is no data )
  15. laptech
    laptech Well-Known Member
  16. vinaybs
    vinaybs Well-Known Member
    hi
    require Schematic
    current Unavailable
  18. esmerlin
    esmerlin Well-Known Member
    i need schematic for lenovo flex 3 1580
    LT41 SKL MB 14292-1 448.06701.0011
  20. AbcLaptops S.A
    AbcLaptops S.A Well-Known Member
Similar Threads - Lenovo 300S LT41 Forum Date
Lenovo 300S-14ISK BIOS/UEFI May 5, 2017
BIOS PC Lenovo S200, ideacentre 300S-11IBR, 300-20IBR IBSWME V1.0 BIOS/UEFI Mar 14, 2016
Lenovo AIZS1 LA-C582P BIOS/UEFI Oct 5, 2021
BIOS PC lenovo yoga 310s-11iap BIOS/UEFI Mar 5, 2020
