Asus X550VX
Discussion in 'Schematics' started by technical, Apr 19, 2016.
    me miếc gì chưa...
  2. TrungTin
    TrungTin New Member
    Anh Thien clear me giup em file goc main asus X550VX REV 2.0 vga roi , file cua anh chep xong mat nguon cpu luon.
    25q64fv_Clear me.bin
  4. 05ifix
    05ifix Moderator
    I have this board Asus X550VX REV 2.0 , i5-6300HQ, graphic N16P-GT-A2 - the laptop starts with *power led on *wifi led on *caps on *num on , with no voltage for processor and graphic , the kbc IT8995E have dump ?
    IT8995E have dump.
  6. 05ifix
    05ifix Moderator
    can you give ? kbc dump ?
    X550VX ECROM
  8. 05ifix
    05ifix Moderator
    I did not find anyware pinout for IT8995E , can you help me ?
    Yes, You need to find out about it, Depending on the programming tool that has different connection, We can not help any more :(
  10. 03ifix
    I HAVE 3 MODEL TRY MAYBE HELP.
  11. 05ifix
    05ifix Moderator
    Ram disable diagram ?
  12. 05ifix
    05ifix Moderator
    with money :D , cannot show me how ? a photo
  13. nexial
    nexial Well-Known Member
    Hi! need clear_me
  15. 23ifix
    23ifix Moderator
    ASUS R510V mainboard x550vx rev 2.0 test ok
    mouez_by and technical like this.
  16. manusr
    manusr New Member
    Hi, did you solve this issue? i have the same problem.
    I dont know to configure my svod3 for dump and write kbc dump. Motherboard inst in date base.
    Can someone to help me?
    can not connect or what problem?
  18. manusr
    manusr New Member
    HI! I have a laptop with motherboard x550vxk. Laptop doesnt power on, it have *power led on *wifi led on *caps on *num on , with no voltage for processor and graphic , the kbc IT8995E.
    I tried to write KBC with dump and i couldnt connect with KBC.
    I solved connecting issue selecting ASUS r510 motherboard in SVOD data base and reset the programmer.
    But motherboard continues with same problem... I will try replacing KBC...
    Thanks for reply.
  19. jasko_jacker_1
    jasko_jacker_1 New Member
    I have the same problem, probably pch issue because change KBC don't solve
    If you have problem to read kbc it's very important that the original bios is in use, with a
    dump there is a problem to read kbc with vertyanov programmer I don't know with other programmer but I think it's the same.
    #40 jasko_jacker_1, Dec 15, 2018
Similar Threads - Asus X550VX Forum Date
Asus A550VX X550VXK 2.0 BIOS/UEFI Feb 21, 2018
