Apple Apple BJ43 MLB_051-9800 820-3437 A1466
Discussion in 'Schematics' started by technical, Oct 2, 2014.
    Yes, Please check hardware, chipset....
  2. selim yazıcı
    selim yazıcı Well-Known Member
    Please help My board i5 1.4 2014 my bıos repair
    how to clear me region I dont know
  3. 12ifix
    12ifix Moderator
    hi admin. please help. why after flashing the bios, became cannot enter osx? what should i do?
    i try to reinstall osx, also the same. please help.
    before where Programming it how ?
  5. 12ifix
    12ifix Moderator
    i have an experience for example, years ago, have a macbook air a1466 (efi lock), after change the bios, efi lock and icloud gone. but have a same symptons, cannot enter osx. today i got the same problem. but from the start, it cannot enter osx, ssd in good condition. i think should be have a problem in bios. any suggest?
    You need keep old bios only remove password.
    https://vinafix.com/resources/how-to-remove-password-bios-apple-add-edit-serial-number.1209/
    Unlock - How to remove password Bios Apple & Add, edit Serial...
    Manual document .pdf 1. Use tool ( TL866 or 610P ...etc ) backup BIOS has password. 2. Open BIOS use software HxD remove password. 3. Done and Programming. You need to be a hardware technical to...
    vinafix.com
  7. 12ifix
    12ifix Moderator
    Use bios Please clear me.
  9. 12ifix
    12ifix Moderator
    okey, i'll try next time. thank for your help. i'll follow up for the next issue.
  10. apagal
    apagal New Member
    hi any one can help me to give me the solution to remove the efi without removing the bios chip from the mac plz
  11. 01ifix
    here: https://ghostlyhaks.com/shop
  12. 11ifix
    11ifix Moderator
    Dear Admin
    Please remove the password from given file.
    Big thanks
  13. 11ifix
    11ifix Moderator
    please dont mind Admin
    check mail
  15. 05ifix
    05ifix Moderator
  16. jose0417
    jose0417 Well-Known Member
  18. laptoprep123
    laptoprep123 Well-Known Member
Similar Threads - Apple BJ43 MLB_051 Forum Date
APPLE iMac 21.5" A1418 820-01061-A BIOS/UEFI Aug 17, 2019
Apple SPI J6100 for MacBook , Air Pro 2010-2017 SPI-ROM Cable New 2019 Apple spi Computer Hardware Repair Mar 8, 2019
APPLE MAC Conversion Discrete to UMA Pls BIOS/UEFI Sep 27, 2018
need working bios for 820-3332 for Apple MacBook Pro 15" retina 2012 BIOS/UEFI Aug 8, 2018
Need clean ME Apple MBP 17in 820-2914 BIOS/UEFI Jul 5, 2018
