HP-Compaq Still Warning machine is not in committed state
Discussion in 'BIOS/UEFI' started by effektiveddd, Jan 14, 2018.
  1. effektiveddd
    effektiveddd Well-Known Member
    Hi,
    I add to my bios serial etc. and i have still information:
    ,,Warning machine is not in committed state''.
    My BIOS setting export to config.txt
    Help me.
    HP 840 G2
    Similar Threads - Still Warning machine Forum Date
    Kinh nghiệm WARNING !!!! MSI MS-16P11 LCD 40 PIN 120HZ 3D 17.3" Computer Hardware Repair Jun 25, 2019
    Warning!! - machine is not in committed state! Computer Hardware Repair Jun 29, 2016
    Please send two file OLD bios error and bios new you Programming. i not need file txt above.
    effektiveddd likes this.
  4. effektiveddd
    Hi,
    I don't have oryginal bios file, because i buy this laptop with faulty bios. Bios was clean.
    In the attachment, the current bios.
    bios this error how? send one photo i check.
  6. effektiveddd
    Laptop works but wen i turn on, i have this notice.
    I try Downgrade / Upgrade bios from BIOS & HP LAN update. But still have this warning.
    #5 effektiveddd, Jan 14, 2018
  7. 03ifix
    You try this video link.
  8. effektiveddd
  9. 03ifix
    did try this methods?
  10. effektiveddd
    Yes i tried this. I check many information, YT video etc. before created this post.
  11. 03ifix
    This is latest version dmi tools try this maybe some help.
  12. 03ifix
  13. effektiveddd
    When i tryied use:
    4.Once at the DOS prompt, type in nbdmifit.bat and press enter.
    5.Fill in all the information as prompted.''
    Then i have problem:
    img1.
    When i use :
    If you are getting MDM (manufacture programing mode) locked, the do the folowing:
    1. Shut down notebook
    2. Press WIN+UP+DOWN and the power button, HOLDING IT FOR at least 2 seconds''
    Then i have message:
    img2.
    When i use boot from file, and choose BRAND14 :
    img3.
    can find one bios other is fast late.
  15. 01ifix
  16. effektiveddd
    Thank all for help. I only wasted my and yours time. I downloaded a different BIOS and solved the problem;)
    old bios error you have backup save before where Programming
  18. 01ifix
    can reply what bios you use for solve your problem ?
  19. effektiveddd
    Good BIOS file.
    I buy laptop with clean (damage) BIOS .
  20. Maz_Lab
    Maz_Lab Well-Known Member
    how to add serial etc. in bios
  21. Maz_Lab
    Did solve.the problem
