ASUS Vivobook F556U X556UV CPU 6th BIOS X556UV Rev 3.1 Boardview Asus X556UV 3.1.fz Processor Intel® Core™ i7 6500U Processor, Intel® Core™ i5 6200U Processor, Intel® Core™ i3 6100U Processor, Operating System Windows 10 Home Windows 10 Pro Memory DDR4 2133MHz SDRAM, 1 x SO-DIMM socket for expansion, up to 12 GB SDRAM Display 15.6" (16:9) LED backlit HD (1366x768) Glare Panel with 45% NTSC 15.6" (16:9) LED backlit HD (1366x768) Anit-Glaire Panel with 45% NTSC 15.6" (16:9) LED backlit FHD (1920x1080) Anit-Glaire Panel with 45% NTSC Graphic NVIDIA GeForce 920MX , with 2GB VRAM Storage Hard Drives: 500GB/1TB 5400RPM SATA HDD 2TB 5400RPM SATA HDD 500GB/750GB/1TB 7200RPM SATA HDD Solid State Drives: 128GB/256GB SATA3 SSD Optical Drive Super-Multi DVD Keyboard Chicklet keyboard with isolated Num key Card Reader Multi-format card reader (SD/SDHC/SDXC) WebCam VGA Web Camera Networking Wi-Fi Integrated 802.11b/g/n 10/100/1000 Base T Bluetooth Built-in Bluetooth V4.0 (Optional) Interface 1 x COMBO audio jack 1 x VGA port/Mini D-sub 15-pin for external monitor 1 x USB 3.0 port(s) 1 x USB 2.0 port(s) 1 x USB-C Gen 1 (up to 5 Gbps) 1 x RJ45 LAN Jack for LAN insert 1 x HDMI Audio ASUS SonicMaster Technology Battery 2 Cells 38 Whrs Polymer Battery Power Adapter Plug Type :ø4 (mm) Output : 19 V DC, 3.42 A, 65 W Input : 100 -240 V AC, 50/60 Hz universal 3/ 2 pin compact power supply system Dimensions 38.2 x 25.8 x 2.55 cm (WxDxH) Weight 2.3 kg (with 2 cell battery) with Battery Security Kensington lock BIOS Booting User Password Protection HDD User Password Protection and Security Manufacturer Warranty 1-year limited International hardware warranty. *different by country
model: asus k556u pcb code: x556uv_mb rev 3.1 its administor password...plz help sir,administor password are removed...
https://vinafix.com/threads/asus-vivobook-x556uv.23853/#post-69196 ASUS Vivobook X556UV ASUS Vivobook F556U X556UV CPU 6th BIOS X556UV Rev 3.1 Boardview Asus X556UV 3.1.fz ASUS X556UV-X556UJ-X556UA-X556UB-X556UF-X556UQ-X556UQK-X556UR REV3.1.pdf Processor Intel® Core™ i7 6500U... vinafix.com
TRY THIS PASSWORD 1 BY 1. 1 PASSWORD IS WORKING AND REPLY IF WORK.THIS PASSWORD DATE 2016/09/05. AA94LO0B BA94LO0B LA94LO0B OA94LO0B DA94LO0B 1A94LO0B 0A94LO0B 9A94LO0B 4A94LO0B 2A94LO0B CA94LO0B HA94LO0B
