Có file lên OK vào Win của Vostro 3468, nhưng bios có Pass Admin ko tùy chỉnh trong bios được, chạy UEFI.
Hi xin vui lòng bạn có thể sắp xếp các tập tin này http://laptopblue.com/threads/bios-dell-vostro-14-3468-vegas-turis-skl-kbl-15341-1-ok.47913/
its still the same ie. late display !!! display comes after 15 seconds which need to be within 5-6 second !!!! the bios file which u edited and make it clear me and re-uploaded it is still same late display !!! plz do it again if u can than thank you !!!
You need to do it yourself, May need to retry many times. https://vinafix.com/resources/how-to-clear-me-region.1188/ How to Clear ME Region The Intel Management Engine (ME), also known as the Manageability Engine, isan autonomous subsystem that has been incorporated in virtually all of Intel'sprocessor chipsets since 2008. ... It is a... vinafix.com
i have dell 3467 (P/N vegas_turis skl_kbl)laptop in 55% not charging problem i solved problem on bios reprogramming bt display delay problem create can you fixed 55% not charging problen in old bios file
