Apple Easy READ AND WRITE THE EFI-ROM MACBOOK PRO 13" and 15" late 2016 , 2017
Discussion in 'BIOS/UEFI' started by 21ifix, Apr 12, 2017.
  1. 21ifix
    21ifix Moderator
    - Read , Erase and Write the EFI-ROM on
    MacBook Pro 15-inch Touch Bar A1707 820-00281-10 BIOS
    MacBook Pro 13" A1708 Late 2016 820-00875-01 BIOS 820-00875-a
    #1 21ifix, Apr 12, 2017
  3. 01ifix
    what programmer you use ?
  4. 21ifix
    21ifix Moderator
    EZP2010 , REVELPROG IS
  5. 21ifix
    21ifix Moderator
    i used Easy Flash to flash EFROM MX25L6406E
  6. 01ifix
    use socket sop8 ? or what error you have ?
  7. 21ifix
    21ifix Moderator
    The problem solved , close Topic
    i can unlock EFI 2016 :blush:
  8. K-PAX
    K-PAX Well-Known Member
    hi vnn567 ,how resolved?
  9. K-PAX
    you put ac adapter and battery for programming?
  10. 01ifix
    yes maybe can post your solution here for help others.
  11. 21ifix
    21ifix Moderator
    - Read , Write the EFI-ROM on MacBook Pro 13 " and 15" model 2016 A1708 , A1706 , A1707
    - Read , Write the EFI-ROM on MacBook Pro 13 " and 15" model 2017 A1708 , A1706 , A1707
    #10 21ifix, Nov 15, 2017
  12. 01ifix
    programmer RT809H can do it also.
  13. 21ifix
    21ifix Moderator
  14. nanooshazi
    nanooshazi New Member
    u can remove any mac cloud password to reprom bios if u dnt have efi adpter u can use normol bios adpter using wire to soldring efi winbond 25q64fw n copy new bin file
  15. 21ifix
    21ifix Moderator
    too bad ,
  16. nanooshazi
    thats better for me dear bcoz no tool
  17. 21ifix
    21ifix Moderator
    your method cannot do it
  18. Canto
    Canto New Member
    vnn567, forums and for help and share. If you have solution, please share with others.
  19. Canto
    Canto New Member
  20. 05ifix
    05ifix Moderator
    It works. Tried and can read and write. The file can download from Medusa to PC using minipro or any tool you have. Cannot copy directly to PC but Medusa can unlock, read, write and check the firmware.
