Now fast https://vinafix.com/resources/how-t...efi-hp-elitebook-elitebook-folio-series.1210/ Unlock - How to remove password BIOS/UEFI HP Guide remove password BIOS UEFI HP Support all HP: - Guide pdf and video. - Remove password encryption use software edit hex. You need to be a hardware technical to read bios backup if you don't... vinafix.com
Hi all, I just registered to the forum. I spent quite a long time searching the web and studying some documents trying to understand how to reset the BIOS password for a HP elitebook 820 G3 I bought second hand. I discovered only later that the BIOS was locked by a password and realized it is impossible to reset the bios password unless you call HP to get a unique smc.bin file or replace the BIOS chip. I am moving on this last solution and I ordered the BIOS chip that is a winbond 25Q128FV. Before doing that I am kindly asking you any advice about this procedure. The vendor told me the chip is loaded with latest firmware and nothing more than replace the chip is required. I want to be sure this is correct and I will note face any other problem. It appears to me that the chip could be missing the basic info about the laptop...am I correct. What should I do in this case? Is there any other software procedure?
Hi thank you very much for your support. I just need to know if your solution is an hardware solution or a software solution. My situation is I have a laptop elitebook 820 G3 and I can NOT enter/change/update the BIOS as it is password looked. I am not sure if the laptop can boot from another device. Please let me know. Thank you
**You need to be a hardware repair technician and know Programming bios. Our solution is to edit the hex in the bios file...
Hi, I am sorry but I am not sure about your answer. I would appreciate a little bit more clear explanation so that I can understand if I am able or not to do the job. I can work with file editing but, AGAIN, I can not enter the bIOS because of the pw. Thanks for your understanding.. I need to be sure before proceedind.
where your bios? bkup bios and send i try remove when remove password when check what edit your bios.
orry could not reply before. I would like to sed you the backup but I do not know how to extract the BIOS. I am having a look over the web. If I succed I will send it to yoy. If you wish to instructye me how to extract BIOS I will be pleased.
You want remove password Please buy Tutorial this https://vinafix.com/resources/how-t...efi-hp-elitebook-elitebook-folio-series.1210/ Unlock - How to remove password BIOS/UEFI HP Guide remove password BIOS UEFI HP Support all HP: - Guide pdf and video. - Remove password encryption use software edit hex. You need to be a hardware technical to read bios backup if you don't... vinafix.com or Buy VIP and get support https://vinafix.com/account/upgrades Account register vinafix.com Sorry we not free..
