Hi, V310-15ISK and v310-15IKB motherboard numbers are same(da0lv6mb6f) but even though when I use v310-15ISK bios for v310-15IKB it doesnt work I tried the bios v310-15IKB which is working properly for the motherboard which is not working,i realized after 30 seconds it starts to work, please see the back up for the bios for the working device, if you have a bios for 310-15IKB Could you please send?
here https://vinafix.com/threads/lenovo-v310-14isk-v310-15isk-da0lv6mb6f0.24018/ Lenovo V310-14ISK, V310-15ISK - DA0LV6MB6F0 Lenovo V310-14ISK, V310-15ISK BIOS 0zcn11ww DA0LV6MB6F0 REV: F Quanta LV6 Schematics boardview DA0LV6MB6F0 LV6 ECROM IT8886he.bin vinafix.com
We tested the bios there, not opening. I copied v310-15IKB bios from the computer that worked fine. I'm trying to open after 30 seconds. ------------------------------------------------------------------------------------------------- It's opening after 30 seconds.
V310-15IKB_Clear me.BIN.zip not working. What is the difference between the bios that opens 30 seconds late and the bios you throw?
i can help what ? Or you can clear me. https://vinafix.com/resources/how-to-clear-me-region.1188/ How to Clear ME Region The Intel Management Engine (ME), also known as the Manageability Engine, isan autonomous subsystem that has been incorporated in virtually all of Intel'sprocessor chipsets since 2008. ... It is a... vinafix.com
Your bios do not work. Are you sure bios are working? I give you bios working, you are doing clear me, it is not working.
the same model, but the bios that I cloned from the running device is booting up but after 20 seconds the image is coming. I sent you the original working bios, you bios clear me , then it never came to work.
