HP-Compaq clear me please HP EliteBook 820 G3 Notebook 6050A2725001-MB-A01
Discussion in 'BIOS/UEFI' started by racchid, May 6, 2017.
  1. racchid
    racchid Well-Known Member
    Similar Threads - clear please EliteBook Forum Date
    HP-Compaq Please clear password BIOS/UEFI Mar 30, 2017
    HP-640 G1-6050A2566302-MB-A03.BIN-CLEAR BIOS/UEFI Jul 20, 2021
    LA-9981P-3537-THANGCLEAR.BIN-new BIOS/UEFI Jul 20, 2021
    VOSTRO 3578-3478-3476-3576-THANG-CLEARME BIOS/UEFI Jul 20, 2021
    A Thien clear giup e bios nay voi a. BIOS/UEFI Aug 22, 2019
    HP EliteBook 820 G3 Notebook 6050A2725001-MB-A01_ME.bin
  4. racchid
    that is ok
  5. racchid
    thank you
  6. can kurtaran
    can kurtaran Well-Known Member
    hp elitebook 820 G3 password I need unlock it please help me thanx. I add my bios file.
  7. can kurtaran
    pls help me for hp elitebook 820 g3 password. I add my password bios file its up. Pls unlock it.
  9. can kurtaran
    @ ThienBui thanx. it is working.
  10. JENTORIS
    JENTORIS Well-Known Member
    EC 8MB please.
    ec 8mb Please send file old i check..
  12. JENTORIS
    it has password. wait.. i will back up it
  13. JENTORIS
    here is ec file
  14. JENTORIS
    please post main Bios and EC. it doesn"t work if I flash main only
    You only need remove password in file 16MB or Programming bios new you need Clear me before Programming....
  16. JENTORIS
    The problem is the 16MB bios is error while trying to remove the password, it doesn't boot anymore. please help me to fix it.
  18. JENTORIS
    THANKS A LOT. I WILL TRY IT.
  19. vince59
    vince59 New Member
    Hi all,
    I just registered to the forum. I spent quite a long time searching the web and studying some documents trying to understand how to reset the BIOS password for a HP elitebook 820 G3 I bought second hand. I discovered only later that the BIOS was locked by a password and realized it is impossible to reset the bios password unless you call HP to get a unique smc.bin file or replace the BIOS chip. I am moving on this last solution and I ordered the BIOS chip that is a winbond 25Q128FV. Before doing that I am kindly asking you any advice about this procedure. The vendor told me the chip is loaded with latest firmware and nothing more than replace the chip is required. I want to be sure this is correct and I will note face any other problem. It appears to me that the chip could be missing the basic info about the laptop...am I correct. What should I do in this case?
    Is there any other software procedure?
  20. BigPunk
    BigPunk New Member
    @vince59
    It seams you bought a Bios chip with clean ME. I would give it a try.
    My question now:
    I have 820 G3 and I dumped the BIOS (look at file)
    I cleaned the password and flashed it back but the machine flashes 3x times and goes off.
    I flashed the original back but the same problem (flashes 3x time and then off) :(
    Should I program the 8mb file, too? Or Am I missing something?
