Special ! ITE ENE IO Programmer , ITE8586,KB9012,Nuvoton,EDID + Keyboard Module
Discussion in 'Computer Hardware Repair' started by sas2017, Jun 3, 2017.
  1. CHADI BDEWI
    CHADI BDEWI Well-Known Member
    ok thank
  2. sistana
    sistana New Member
    Maxim The devices you sell Maxim are too bad. Altera and Atmel pins are very bad oxidized
    I'm not lying.
    Only facts and Evidence
    Important feet oxidized and communication problems. Why pin oxide ?
    0caa2e08c8354a7144b42be627b01926.
    2. Photo
    8deffc7775876834399570901c6e0d05.
    Photo source : photo_2017-08-18_10-33-19.jpg
    Photo 2 source : Vertyanov_Programmer_Solution.png
  3. dnalaptop
    dnalaptop Well-Known Member
    HOW UPDATE NEW DATA CONNECTION , PLEASE SHARE.
  4. sas2017
    sas2017 Well-Known Member
    ENE IO Sample : Mainboard LA-8941P
    Schematic Search keyboard pin KSO3 , KSI4 , KSI7 , KSI6 , KSI5
    Keyboard pin number contact address write.
    Result : LA-8941P KSO3=8 KSI4=14 KSI7=20 KSI6=17 KSI5=16
    this information MB connection ENE txt file add and finish ;)
    ITE same !
    PD0= PD1 , PD2 , PD3, PD4, PD5, PD6, PD7, BUSY, STB, AFD, INIT, SLIN, KSI4, KSI5
  5. inwerp
    inwerp Well-Known Member
    Guys... i have contacted Vertyanov himself: this is a ripoff which will not be supported by the further software updates. I asked him if he could contact vinafix admin to fix this post and give right place to buy this kit.
    The original device is also cheaper.
    if you don't care - you're just stupid since every $$ you paid for the ripoff was stolen from the original developer. This means that newer product for newer IO chips will be harder to develop, so you're literally hurting yourself. Yup, there's no problem in hijacking Apple products, e.g MacBook 2015 data rescue kit, but this is a niche device which could only loan itself if users and buyers will respect author's copyright. So far, this eBay seller literally stole 10k $$ from the development which needs to be supported since newer IO chips come to the market.
    #25 inwerp, Jun 4, 2018
    Jose Rei and 22ifix like this.
  6. 12ifix
    12ifix Moderator
    any body know, how to read npce288 use this tool?
    it seem, it not work 100%. only in la-b091p working, another board that use npce288/388 not working.
    please help, if anybody ever success read this nuvoton with this tool. thanks.
  7. 22ifix
    22ifix Moderator
    some of 288 is bad
    it is not programmers problem
    you may ask author directly (Vertyanov)
    please use new software
    Maxim
  8. 12ifix
    12ifix Moderator
    just now i mean for sas io programmer, not vertyanov real version. btw, thanks in advance.
    so the newest version of vertyanov, i can buy from where?
  9. 22ifix
    22ifix Moderator
    show please photo of board
  10. 12ifix
    12ifix Moderator
    here is mine.
  11. 22ifix
    22ifix Moderator
  12. 12ifix
    12ifix Moderator
    yes, i know. so i think i need the real one. even the old one still can use, i'll keep it for back up tool.
    #32 12ifix, Oct 16, 2018
  13. Rodolfo Felix
    Rodolfo Felix Well-Known Member
    LA-C285P EC 388N FFC_PINS = 30 JENK = 23 TCK = 11 TMS = 10 TDI = 9 TDO = 20
    LA-C771P EC 388N FFC_PINS = 30 JENK = 24 TCK = 12 TMS = 11 TDI = 10 TDO = 21
    Trabaja 100% S A S
  14. iclsl
    iclsl New Member
    Does this recorder need a license to record?
    sorry i don't understand what you mean.
  16. iclsl
    iclsl New Member
    [QUOTE = "ThienBui, postagem: 102308, membro: 6"] desculpe, eu não entendi o que você quis dizer. [/ QUOTE]
    I was going to buy the SVOD but I was advised that he had a license to record ENE and Nouvoton chips, as if it were a serial. I do not know if it's exactly a license. But in the ad it said that it comes with 2 codes.
  17. cdwayne foremost
    cdwayne foremost Well-Known Member
    where can i get the software to download ???
  18. iclsl
    iclsl New Member
    Check with your dealer, he should have to pass the software and manual
  19. cdwayne foremost
    thanks alot i got them now..
  20. Nasir Mahmood
    Nasir Mahmood Well-Known Member
    HI.
    I want to program it8586e for motherboard BE460 NM-A551 for this i need data sheet of pin .... i dont have io programmer i will program this with rt809f trough connect wire/jumper on keyboard connecter plz help
Similar Threads - Special Programmer ITE8586 Forum Date
BIOS PC HP Beats Special Edition 23-n010 All-in-One - (Lantana) BIOS/UEFI Sep 11, 2016
BIOS PC Blitz Formula (Special Edition) BIOS/UEFI Aug 23, 2015
KB9012QF+EDID eeprom USB Programmer + keyboard tester VER 3.5 New Version Computer Hardware Repair May 25, 2018
Full Set KB9012QF+EDID eeprom USB Programmer + keyboard tester VER 3.2 Computer Hardware Repair Jun 22, 2017
RT809F programmer software release Computer Hardware Repair Jun 2, 2017
