Special ! ITE ENE IO Programmer , ITE8586,KB9012,Nuvoton,EDID + Keyboard Module
Discussion in 'Computer Hardware Repair' started by sas2017, Jun 3, 2017.
  1. sas2017
    sas2017 Well-Known Member
    IR16 , vertyanov, svod io programmer , ENE KB9010 / KB9012 / KB9022 / IT8586E, IT8585E, MEC1609 programmer , io programmer , ene programmer , ite programmer
    KB9012QF + EDID USB programmer + Notebook keyboard tester, kb9012 programmer
    IT8586 programmer
    We do not have any activations.
    IT8585E - tested on X550LA
    IT8586E - tested on NM-A311
    IT8587E - tested on ZQK
    IT8985E - tested on X551MA
    Contact : [email protected]
    1.
    2.
    ***Special version***
    ***3 keyboard socket***
    ***High amperage supply***
    ***Type B strong USB socket***
    ***Fast and easy programming
    No Activation All Free !
    NUVOTON NPCE288 NPCE388 series
    NPCE288NA0DX TQFP128 (no external adapter needed!)
    Package Included
    1 x IO programmer
    1 x keyboard converter pcb
    1 x 1.8v bios adapter
    1 x 32 pin 1mm cable
    1 x 30 Pin 1mm cable
    1 x 26 Pin 1mm cable
    1 x 24 Pin 1mm cable
    1 x 30 Pin 0.8 mm cable
    1 x 30 Pin 0.5 mm cable
    1 x 26 Pin 0.8 mm cable
    1 x 25 Pin 1mm cable
    1 x 28 Pin 1mm cable
    1 x Dupont cable
    1 x 40 pin ve 30 pin lcd edid programmer cable
    1 x FC-8P 8 Pin IDC programmer cable
    Buy Link : http://www.ebay.com/itm/Vertyanov-I...611949?hash=item28388f5f2d:g:adsAAOSwTLxZhFMK
    Campaign : http://www.ebay.com/itm/KB9012QF-ED...920087?hash=item283bbcca17:g:pFAAAOSwk~xZhFJk
      265 KB
      6
      329.1 KB
      6
      332.1 KB
      4
      341.1 KB
      5
      24.7 KB
      4
      604.8 KB
      6
      273.3 KB
      4
      333.6 KB
      5
    #1 sas2017, Jun 3, 2017
    gmedia likes this.
    Similar Threads - Special Programmer ITE8586 Forum Date
    BIOS PC HP Beats Special Edition 23-n010 All-in-One - (Lantana) BIOS/UEFI Sep 11, 2016
    BIOS PC Blitz Formula (Special Edition) BIOS/UEFI Aug 23, 2015
    KB9012QF+EDID eeprom USB Programmer + keyboard tester VER 3.5 New Version Computer Hardware Repair May 25, 2018
    Full Set KB9012QF+EDID eeprom USB Programmer + keyboard tester VER 3.2 Computer Hardware Repair Jun 22, 2017
    RT809F programmer software release Computer Hardware Repair Jun 2, 2017
  3. 17ifix
    17ifix Moderator
    I special device used very good thank you
    sas2017 likes this.
  4. Damith shanaka
    Damith shanaka New Member
    Cargo arrived :D
    I am very happy the device is working very nicely.
    Thank you my friend will order again
  5. 22ifix
    22ifix Moderator
    hi sell fake copy programmer
    original - VER3 from S.Vertyanov
    #4 22ifix, Aug 3, 2017
  6. aacom
    aacom New Member
    Thank you
  7. sistana
    sistana New Member
    You are lying. It works very well. Excellent service.
  8. sistana
    sistana New Member
    thank you device very good ! :D
  9. 01ifix
    @sas2017 when will be available for buy ?
    i want buy this great tool
    regards.
    sas2017 likes this.
  10. sas2017
  11. 22ifix
    22ifix Moderator
    its not working with new original software ! only with old or fake copyes
  12. sistana
    sistana New Member
    I notebook1 forum 4a and 4b software download and tested no problem friend.
    Why are you lying ? Maybe you write Ebay Comment.
    All software tested no problem.
  13. tomazek
    tomazek New Member
    SAS device used software 4b maxim , very nice worked.
    Don't lie to people, the device works smoothly.
  14. 22ifix
    22ifix Moderator
    Buying stolen things you help the thief !
  15. sistana
    sistana New Member
    why ebay 24 positive feedback comment and why 1 comment Neutral ?
    You know the answer is maxim. maybe you did.
    you pcb2 version only 1 keyboard connector sas 3 keyboard connector and easy device.. no need adapter.
    You lie because you are superior to your device.
    Please, everyone, take care.:non:
    #14 sistana, Aug 9, 2017
  16. 17ifix
    17ifix Moderator
    Maxim ,
    The device works smoothly with 4b software. What's your problem?
    Look at your business, please.
    Good night. :nrg:
  17. 17ifix
    17ifix Moderator
    Is there a way to increase the timeout when reading/writing ENE chips?
    Board Info: HP Pavilion 15-ab127ca (da0x22mb6d0)
    SIO: KB9028Q
    Why you device error kb9028 ?
    Sas write all io no problem
  18. sistana
    sistana New Member
    30e0740d8afd7d09559e79ad973717ca.
  19. CHADI BDEWI
    CHADI BDEWI Well-Known Member
    hello
    how are you
    ı have svod programmer lıke that
    but ı have a problem when ı programmıng ıte ıo
    ıte devıce not detected
    ı have actıvatıon for ıte and novtoun
    can you help me
    thanks
    h
  20. sas2017
    svod programmer not support friend.
    only sas and vertyanov programmer support.
    sas programmer no need activation
    You can text the SVOD support team.
