HP ElitePad 1000 G2 Tablet ZPJA0 LA-A271P Rev 1.0
Discussion in 'BIOS/UEFI' started by technical, Jun 2, 2017.
    ZPJA0 LA-A271P Rev:1.0
    BIOS L84_0141
    Similar Threads - ElitePad 1000 Tablet Forum Date
    Schematics PC HP ElitePad 1000 G2 Healthcare Tablet BIOS Schematics Jun 2, 2017
    i need bios ELITEPAD 1000 G2 BIOS/UEFI Feb 20, 2016
    HP ElitePad 900 G1 Tablet BIOS/UEFI Aug 10, 2015
    BIOS PC HP BTD-3ND V1.0 15-KE1-011000 BIOS BIOS/UEFI Aug 14, 2019
    Dell Chromebook 13 7310 Wistron 4PD04F010001-MB 14271-1 BIOS BIOS/UEFI Aug 12, 2019
  3. ArskaL
    ArskaL New Member
    Hi!
    Im trying to reprogram the bios with ch341a on the elitepad 1000 G2 tablet with this bios file but still cant get it to boot up. there's nothing on the screen and the windows button just blinks briefly when i press the power button.
    old bios error what? bios we backup from machine work
  5. ArskaL
    ArskaL New Member
    Yes it is an old bios error. The programming seems to go right when i do it without the powercable connected to the motherboard (and also battery is disconnected) but when the powercable is connected to the motherboard it won program it like it should.
    bios old error what? can try clea me
  7. ArskaL
    ArskaL New Member
    I dont exactly know what bios error because i got the tablet when it was at this stage. So it just wont boot up and doesnt show any error or anything on the display when i push the power button. It just flashes the windows key light and makes a little vibration.
    you need check hardware..
  9. ArskaL
    ArskaL New Member
    Do
    Do you know is there a way to check if the motherboard is broken?
    You do not have to be a hardware repair technician ?
  11. ArskaL
    ArskaL New Member
    No im not a hardware repair technician.
  12. ArskaL
    ArskaL New Member
    And also, can the bios chip be damaged by inserting too much voltage? The chip is the winbond w25q64fw and runs on 1.8v.
  13. ArskaL
    ArskaL New Member
    So can it be damaged by trying to program it with a 3.3v programmer?
    tool Programming you use ?
  15. ArskaL
    ArskaL New Member
    Im using the CH341A usb programmer. But first i tried it without the 1.8v adapter
    I not use CH341A.
    So i can not support you, Need to contact where you buy it to ask.
