HMK-G41A HTM265 Rev 3.0
Discussion in 'BIOS/UEFI' started by technical, Oct 22, 2016.
    HMK-G41A HTM265 rev3.0
    HT265H03
    Similar Threads - G41A HTM265 Forum Date
    BIOS PC Foxconn G41AP BIOS BIOS/UEFI Sep 23, 2016
    Schematics PC G41A-M7S G31A-M7S Schematics Nov 3, 2014
    Schematics PC IG41A-M7S-V6.6S Schematics Oct 31, 2014
    HTM265 REV1.0 D1 D2 9b BIOS/UEFI Nov 30, 2014
  3. Miri
    Miri New Member
    Hi. I need other bios dump for HMK-G41A HTM265 rev3.0.
    Can u help me ?
    no Understand. bios above have problem what ?
  5. Miri
    Miri New Member
    Motherboard HMK-G41A HTM265 rev3.0
    When i use your dump for rev 3, USB ports not working
    And when I use this dump for rev 1 USB ports working but have other problems.
    problem other is problem what ?
    HTM265 1.0 GD25Q80 HMK-G41
  9. Miri
    Miri New Member
    When I use rev 1 dump, board working only with one power supply Xlilence ) and not other one/
  10. Miri
    Miri New Member
    When I use your HTM265 1.0 GD25Q80 HMK-G41 and HT265H03.ROM.zip dump USB have a 4.7V.
    And when I use my bios dump HMK_HTM265 _rev_1_OK USB have a 5.1V and USB flash or mouse/keyb are working.
    But works only with one power supply unit
    all bios I provided above same problem ? machine work have display ?
  12. Miri
    Miri New Member
    HT265H03.ROM.zip dump have display but USB VCC 4.7V and keyb/mouse/ flash not working
    I have a dump for rev 1/ When I use this dump USB vcc 5V, have display, OC working good (W7) but working only with one power supply Xilence 450W - not other one
    I think you need check again hardware.
