Disable RAM onboard Asus X45vd r2.0
Discussion in 'Computer Hardware Repair' started by technical, Oct 31, 2016.
    Similar Threads - Disable onboard Asus Forum Date
    UNABLE TO DISABLE ONBOARD RAM ASUS Computer Hardware Repair Aug 20, 2017
    Asus K50IJ rev 2.1 - how to disable onboard memory? Computer Hardware Repair Mar 25, 2017
    Disable RAM onboard Asus S301LA r2.0 r2.2 Computer Hardware Repair Nov 11, 2016
    Disable RAM onboard Asus X552W X550WE REV 2.0 Computer Hardware Repair Nov 9, 2016
    Disable RAM onboard Asus X751MD r1.1 r2.0 Computer Hardware Repair Nov 8, 2016
  3. 36ifix
    36ifix Well-Known Member
    chép rom này thì ram onboard không hoạt động hả anh ?
    Rom đâu mà chép ?
  5. 0909
    0909 Well-Known Member
    help asus x45vd rev:2.0 no display
    rev 2.0
    I can no longer read pictures. disable ram asus x45vd
    yes, downloads op top.
  11. 0909
    Confused to see the picture:tired_face:
    it is boardview, you can open add boardview to view :D
  13. 0909
    JPEG format :sweat:
    you can not open .JPEG ? :mdr: (mdr)
  15. 0909
    I've tried bios update and disable ram, but still not display, help
    disable ram not Related to bios.
  17. 0909
    Yes I understand it I've tried bios update, laptop no display. Trying to disable ram and ram installation ddr3 10600, laptop also no display. Can you see what I mean
    There are many reasons not to have the image you need to check all components in the motherboard
