iReplaced all like in guide of your photos AX1 but not function (black screen) on coil of gpu i have 1.2v , if i remove coil machine start only 1sec. my post card stuck on 17 also tried to flash bios with this https://vinafix.vn/threads/hp-compaq-presario-cq42-g42-quanta-ax1-dis-uma.7993/ but no laucky anyone tried this method with AX168 ? HP - HP COMPAQ PRESARIO CQ42 G42 QUANTA AX1 Discrete UMA da0ax1mb6f0 CQ42 HM55 AX1 595183-001 G62-233NR DA0AX1MB6H1 REV:H QUANTA AX1 HP COMPAQ PRESARIO CQ42 G42 DIS vinafix.com
I bought guide of uma enable , on it are pictures with what need to replace for Ax1 hp. I followed everything as in the picture but no screen . Inviato dal mio SM-N910H utilizzando Tapatalk
Work perfect i make i mistake on pc133 but all work perfect . You are the best Inviato dal mio SM-N910H utilizzando Tapatalk
Today i tried same method like AX138 on AX1J (DAAX1JMB8CO) in this case removed R383 . Work perfectly . i will upload pictures .
Only one problem now cpu temperature is to high 78°C and fan is spinig max. Any suggestion Inviato dal mio SM-N910H utilizzando Tapatalk
100% is problematic. 78% not really matter. take a long treadmill test to see if there are any errors arising.
hi admin.. can i download all resources if i purchase super vip membership? or tell me difference between business plan and super vip.
Hello Super vip's personal account received only one user. Business accounts for multiple users at your store. * All VIP no downloads resources/ebook.
solved my mistake for the FAN is Bios i flashed wiith another bios for ax1 uma. now flashed with original bios and work perfectly..
hi, i hv bought your guide for ax1j non graphic conversion ....i hv done that mentioned in that guide , but no success it still working on amd graphics ..not on intel.. need ur help urgently
