Hi, The owner has changed the bios chip and maybe even me chips. After I reprogrammed the bios and not the me chip, the notebook starts but in order to remove this message "machine is not in committed state" I try first the boot from uefi file method (brand11, etc) , after, i try hp dmi tool, both with no luck. After I have tryed on windows wndmifit but appear this message: "MPM is not unlocked.....please escalate with UUID to get SMC blob to unlock MPM" I have read to modify the FSMC.bin file to SMC.bin file and change the file lockmpm.txt but the MPM is still locked. My UUID is not FFFFFFFFFFFFFFF I have reprogrammed the bios with different files but MPM is still locked. There is a solution from this issue ?
https://vinafix.vn/threads/warning-machine-is-not-in-committed-state.23168/ Warning!! - machine is not in committed state! How to fix? Warning machine is not in committed state Warning: This BIOS is Not for Production Use. Downloads AMTBrand tool Brand11: 1. Copy folder Brand11 to the root of the USB key formatted as... vinafix.com
No luck with ghis procedure if I don"t have a factory UUID with all FFFF it's impossible to make any change because the system detecte the motherboard is used. I'm searching a me file and bios from the same motherboard
https://vinafix.vn/threads/hp-elitebook-840-g2-notebook-bios.16883/ HP EliteBook 840 G2 Notebook - BIOS HP EliteBook 840 G2 Notebook PC HP EliteBook 850 G2 Notebook PC BIOS M71 Version: 01.13 Rev.A vinafix.com
Finally I solve only the machine is not in committed state issue, Remain to solve how change the UUID on ec to all FF if you want to change serial and other info. Maybe it's possible with hex editor but at the owner not interst the change. thanks for help
Please tell me how to fix the "machine is not in committed state" issue? You wrote that you did.... I would also like to know how to unlock MPM counter. Not always flash programmer gives the effects of what I am looking for. thank you in advance
yes i have test this procedur not work win i want unlock mpm i have errue in smc faileur in brand 14 i have errur cant not comit
