Unlock Xóa mật khẩu bios Toshia một số model mới
Discussion in 'Computer Hardware Repair' started by technical, Dec 14, 2013.
    SatelliteP100 & Satellite Pro P100
    Open Wi-FiCover
    Remove Mini Card Wi-Fi card
    Locate & Short Out JP8 for 5 Seconds
    Remove short and turn on
    NO BOOT
    Press & Hold Power button to turn off
    Turn on again & password is cleared
    SatelliteL10, L20, L30 & Satellite Pro L20
    Open Wi-FiCover
    Locate & Short Out JP1 for 15 Seconds (Satellite L10)
    Satellite L20/Pro L20 short out G1
    SatelliteM100 & Tecra A6
    Open MemoryCover
    Remove Memory
    Remove Black plastic insulation
    Locate & Short CMOS CLR1 for 15 Seconds
    NOTE:
    All the following models use the same password removal process.
    Satellite:17xx Series, 1000, 1110,1130, 1200, 1900, 2430, 3000 P20,P30, P33, A30, A70,A80, M40X, M50,M60, M70, M100
    TecraA3/S2, A5, A6
    The jumper isalways located under or near the memory modules
    Depending on the model the jumper could be labelled J1, J2, J5, J7, J9 or CMOSCLR1 (M100 & A6)
    Satellite,Equium A100 & Tecra A7
    1.Remove Stripcover
    2.Remove 2 x K/B screws
    3.Move K/B Unit up but don’t disconnect
    4.Release & Remove Mini Card Wi-Fi Card
    5.Locate & short C88 Pin 1 & 2 together
    6.Power on Machine while still shorting Pin 1 & 2
    7.As soon as the Toshiba logo appears, remove short
    8.If machine boots, Password has been removed
    Satellite A100 (PSAA2A-02C01N)
    1.RemoveMemory Cover from base of machine
    2.Release & remove right side Memory Module
    3.Lift black plastic insulation
    4.Locate & short PAD500 Pin 1 & 2 together
    5.Power on machine while still shorting Pin 1 & 2
    6.As soon as the TOSHIBA logo appears, remove short
    7.If machine boots, password has been removed
    TECRA A4 & Satellite M40
    1.Open modem& Wi-Fi card cover
    2.Remove mini PCI Wi-Fi card
    3.Lift up black plastic
    4.Locate & short C738 Pin 1 & 2 together
    TECRA S1
    1.Open palmrest cover
    4.Locate & short C5071 Pin 1 & 2 together
    TE-2300
    1.Remove 2 xB12 screws from bottom of system
    2.Remove strip cover
    3.Remove keyboard screws 1 x B2.5 & 1 x SF4
    4.Remove 1 x 4mm screw & Wi-Fi cover
    5.Remove mini PCI Wi-Fi card if fitted
    6.Locate & short points as shown in picture below
    7.Power on machine while still shorting points
    8.Short for 5 seconds
    9.Nothing will appear on the screen
    10.Turn system off holding down power button
    11.Password is now removed
    Satellite A60
    1.Open Wi-Fislot cover
    2.Lift up black plastic
    3.Locate & short C561 Pin 1 & 2 together
    4.Power on machine while still shorting Pin 1 & 2
    5.As soon as the TOSHIBA logo appears, remove short
    6.If machine boots, password has been removed.
    Satellite Pro L40
    1.Open Wi-Fi & RAM slot cover
    2. Locate JRST1 Between Ram and Wifi slot
    3.short JRST1 AND TURN ON SYSTEM.
    4. Short for 15 seconds.
    5. system is shutdown automatic.
    6.turn on the system password is removed.
    Toshiba Satellite Pro L650 l650.
    • Locate G1 or c513 and G2 or C514 to reset Bios
    • In some models it will be B500 under ram cover
    • Works on satellite L650.
    • Importantly, the “B500″. For better contact, welded a small copper wire between the two plots “B500″.
    • Place one strip of memory start.
    • Display the first page of the bios and then extinction of the laptop alone.
    • Remove the small copper wire and put the remaining memory.
    • Restart and that’s OK.
    Toshiba Satellite L700/750
    l700.
    • open ramcover
    • locate G1 for bios reset
    • open ramcover
    • locate J2 for bios reset
    Toshiba Satalite C850
    • Open ram cover
    • locatae B500 short it for a minute
    • restart your laptop with bios password.
    Similar Threads - Xóa mật khẩu Forum Date
    Unlock Xoá mật khẩu BIOS Acer E1-472 EA40 Computer Hardware Repair Sep 10, 2014
    Unlock Xoá mật khẩu BIOS Acer E1-430 EA40 Computer Hardware Repair Sep 10, 2014
    hướng dẫn xóa tài khoản gmail Android Dec 8, 2016
    Google đã xóa hàng ngàn ảnh khỏa thân của sao nữ Windows PC Oct 6, 2014
    Cứ 3 phút có 1 thiết bị di động bị xóa sạch dữ liệu Windows PC Sep 25, 2014
  3. Dht_19030
    Dht_19030 Well-Known Member
    Thank You
    Pham DUy Thang likes this.
  4. rachidxp
    rachidxp Well-Known Member
    PLASE TOSHIBA R30
    model this password in kbc.
  6. rachidxp
    THANK YOU KBC MEC 1618T-AJZP The reset password method
    can need chang kbc new.
    rachidxp likes this.
  8. vandehaai
    vandehaai Well-Known Member
    Hi Thien,
    Cho mình xin cách xóa mật khẩu toshiba satellite r850, thanks.
