Clevo-Axio Clevo P1XXEM P15EM P17EM P150EM P151EM P170EM Sager NP9150
Discussion in 'Schematics' started by laptopmodel, Feb 20, 2014.
  1. laptopmodel
    laptopmodel Moderator
    Shematic laptop Clevo P150EM
    technical and Root like this.
    Similar Threads - Clevo P1XXEM P15EM Forum Date
    Clevo D400E_D410V Schematic Schematics Mar 7, 2020
    Clevo D400E_D410S Schematics Schematics Mar 7, 2020
    Clevo D400E_D410E Schematics Schematics Mar 7, 2020
    Clevo W650SR - BIOS BIOS/UEFI Mar 7, 2020
    ONE K56-2N (Clevo P150EM) BIOS/UEFI Feb 14, 2019
    Bios
    P150EM (5). P150EM (11). P150EM (7). P150EM (9). P150EM (3). P150EM (6). P150EM (10). P150EM (4). P150EM (8). P150EM (1). P150EM (2).
    P150EM P150SMMB-0E BIOS
  5. bga
    bga Moderator
    BIOS P151EM.17
    • 2MB.rar
      232.5 KB
      48
    • 4MB.rar
      2.5 MB
      69
    X911 P375SM 1.00.03
    X511-X911
    P151EM1
    P150EM
    6-71-P15E0-D05A
    p170em (0165408)
    6-71-p15e0-d06af
  10. kwstas800
    kwstas800 New Member
    Hello. Is this working on eurocom p150em? How can i download ?
  12. kwstas800
    Hello. I have problem in clevo p150em. I don't have signal or volts in this pictures. The laptop don't working . Can you help me? The problem is in v core2. It is bd82hm77 the problem or something else? Screenshot_2016-12-11-17-05-39. received_10208027963160637.
  13. kwstas800
    Only in the last picture is the problem. All the other capacitors or mosfet are ok. Thank you for your time
  14. kwstas800
    Bios files for p150em doesn't working
  16. 02ifix
    Hello, Bios for P150SMMB-0D ???
  18. soupapowa
    soupapowa New Member
    Hello,
    I downloaded the bios file for p170em
    I have the same number at the motherboard (6-71-p15e0-d06af)
    And the bios file doesn't work.
    When I want to write the program of file (bin), I have this error :
    Error! CODE Address 0x000011 Buf_Val 0xA5 IC_Val 0xA4
    So I edit your file and I modified the value "A5" to "A4"
    But I have always other errors about values of your file bin.
    I can't change all the values of your file, there are many.
    Are you sure your file (bios) work correctly ?
    Thank you
    This is the problem of IC or machines programming. Not problems of the BIN file.
    p150smmb
  21. sophen
    sophen Well-Known Member
    bios zin update bios khong len hinh chep bios o tren van ko duoc
