GOOD MONING ARE JUST WRITING YOUR FORUM, I WANTED TO ASK, QUALCUNE MEMBERSHIP HAS EXPERIENCE WITH SHUTTLE REWORK STATION STAR SV550A THANKS
I do not use sv550a, you want to ask any problems? you can clear the problem you're having so we refer.
Hello thank you very much, you have various problems, the function does not work AUTOPROFILE, hangs a continuation, user profiles already pre-installed on them, but I have the problem that the cards I deventano dark side bottom, someone has the right procedure to build ad hoc profiles with this rework? you also have some more info to use machines to three areas like mine? how can I change the rate, thanks
Hi Sir, I want perfect BGA profile for Intel 4th Gen BGA CPU(Haswell). I need Soldering and Desoldering profiles. 4th Gen Leaded balls Leadfree balls profiles wanted sir. Machine Type: Shuttle Star Sp360c.
