Apple 1502 - 820-4924
Discussion in 'Schematics' started by technical, Nov 26, 2015.
  1. Darkdesigned
    Darkdesigned New Member
    Did you ever get hold of the correct Board View file ?
    This board wrong ?
    https://vinafix.vn/threads/apple-1502-820-4924.21010/#post-38880
    Apple 1502 820-4924 X304 MLB SCHEMATIC - DVT 051-1573 820-4924-08 A1502 2015_25L6473E 820-4924, 820-4924-A
    vinafix.com
    820-4924-A or 820-4924-B ?
  3. Darkdesigned
  4. Darkdesigned
    Have you managed to find the correct Board View file for the 820-4924-a ?
    Currently I only have the above file.
  6. Darkdesigned
    Ok. But the you should pull the file from the download and rename it to its proper modell cause its not the 820-4924-a so it really misleading. I would pay good money for the correct one, if someone actually had it.
    Yes. Thanks you.
  8. mohamed.mostafa
    mohamed.mostafa Well-Known Member
    BoardView
  9. caingraywood
    caingraywood Well-Known Member
    where can we find the SAM Card shown in this SOP? please give information
  10. caingraywood
    Please answer my question ThienBui
    I do not understand the question :worried:
  12. caingraywood
    1. Open this Document "Memory BR debug SOP", you give this.
    2. you will find inside the document, it says "MOJO cable" and "SAM Card"
    3. Does Vinafix sell these MOJO CABLE and SAM CARD?
    i get 3 beeps on my macbook pro retina. i need to trace faulty ram
    RAM onboard is very difficult to track.
    this document is for reference only. :D
  14. caingraywood
    1. so vinafix dont sell MOJO cable n SAM card? because it can trace faulty ram
    2. do you have any solution?
    1. Yes not sell SAM card.
    2. If the ram is at fault, the best solution is to replace a new motherboard.
    Ram onboard difficult to repair.
  16. 07ifix
    07ifix Moderator
    hi
    i need clear bios 820-4924-a
    model a1502 emc 2835.....
    i have facing problem ( Your computer is disabled" try after 60 minutes. )
  18. 07ifix
    07ifix Moderator
    dear
    i have same problem face in mac book
    (your computer is disabled try again in 60 monutes)
  19. 07ifix
    07ifix Moderator
    now what i do?
Similar Threads - Apple 1502 4924 Forum Date
APPLE A1502 emc2875, 2014-15 820-3476-A need BIOS BIOS/UEFI Jun 17, 2018
Apple Apple a1502 emc2678 820-3476-A BIOS/UEFI Dec 29, 2014
Apple Apple MacBook Pro Retina 13' A1502 051-0052 820-3536 J44 MLB-4G Schematics Jul 21, 2014
APPLE iMac 21.5" A1418 820-01061-A BIOS/UEFI Aug 17, 2019
Apple SPI J6100 for MacBook , Air Pro 2010-2017 SPI-ROM Cable New 2019 Apple spi Computer Hardware Repair Mar 8, 2019
