How to Disable RAM onboard Asus x550cc Just change the location of two resistors. Tips How to Disable RAM onboard Asus Laptops
Buy Tutorial this https://vinafix.vn/resources/how-to-disable-ram-onboard-asus-laptops.1229/ How to Disable RAM onboard Asus Laptops How to Disable RAM onboard many model Asus have support Slot RAM. * Request model must have Boardview. vinafix.com
i am sorry t inform but making this , will make machine not work (no image even with memorys on the slot ) tryed all different rams , LOW voltage and normal voltage , from 1066 to 1600 but all same issue , major part of low voltage make computer to turn on then turn off. anyone sucessfully disabled the onboard and added memorys to the slot and the machine is working ?
or i might not understand , do i have to put <ll the ID to LOW state , or i must p+ut state by state until i notice wich one works ?
what i mmean is , cheking does resistor they are all ID's , so i change them all or one by one to see wich is the correct ID ? , if i change the 3 resistor to the positions you mentioned , it wont work with any memory module
ok like i mentioned , not working , after passing does 3 resistor the positions you mention , no image 1!!!! inserted different rams on it , LOW voltage make machine turn on then off , some outher turn on machine but no image .!!!!
well this machine is giving error s , can't install windows , even with brand new hdd on it , tryed via CD or PEN to install , but gives error of HAL or kernel missing files , cheking google and many websites , amy people resolved the problem by changing memorys on they SLOT , but i got only the onboard memory and gives error on any windows install . if i add a memory module whatever the module , or machine turn on then off or it wont display image. i even think it could be a PCH problems , since i have tons of brand new chips on the lab i replaced it , but still same issue . bios i flashed it with 2 bios , same issue . the onboard memorys were full of flux when i receive the computer . for ex now its giving me error of NTKRNLPA.EXE. when trying to install , i not even arrive to the part were i can delete the HDD , before that it gives errors , truyed with win7 win 8 and win 10 all same issue. diifferent erros , some time that HAL erros or kernel panics . its like some files cannot pass well thru the comunication bus . So thats why i wanted to disable to onboard ram to test with external ram , but if i change position on the 3 resistor you mention , it will turn buut no image , and when i put a memory on the slot or it shut down or it wont display image this machine is killing the entire morning
