Warning!! - machine is not in committed state!
Discussion in 'Computer Hardware Repair' started by technical, Jun 29, 2016.
    How to fix?
    Warning machine is not in committed state
    Warning: This BIOS is Not for Production Use.
    Downloads AMTBrand tool
    Brand11:
    1. Copy folder Brand11 to the root of the USB key formatted as FAT32.
    *** Your USB key should have less than 40 folders and files in the root. ***
    2. Goes to F10 -> System Configuration -> Boot options -> UEFI Boot Mode
    -> Press "Enter" to enable EFI boot -> Select "Accept" -> Save and exit.
    3. Press F9 then "Boot from EFI File", then select your USB key -> Brand11
    -> Bootx64.efi -> Press enter to run startup.nsh
    4. Follow menu to commit AMT and AT.
    Chose 1 to commit VPRO with AT, or 3 to commit Non-VPRO with AT
    5. Press 9 and then Enter key to lock descriptor and reboot the machine.
    6. Press F9 then "Boot from EFI File", then select your USB key -> Brand11
    -> Bootx64.efi. You should see the message "Pass!!! This machine is configured"
    7. Reboot to F10 and disable EFI boot mode. Done.
    Brand12:
    1. Copy folder Brand12 to the root of the USB key formatted as FAT16/FAT32.
    2. Goes to F10 -> System Configuration -> Boot options -> UEFI Boot Mode -> Press "Enter" to enable EFI boot -> Select "Accept" -> Save and exit.
    3. Press F9 then ìBoot from EFI Fileî, then select your USB key -> Brand12 -> Bootx64.efi.
    Brand13:
    1. Copy folder Brand13 to the root of the USB key formatted as FAT16/FAT32.
    2. Goes to F10 -> System Configuration -> Boot options -> Boot Mode -> Choose "UEFI Hybrid" mode -> Save and exit.
    3. Press F9 then ìBoot from EFI Fileî, then select your USB key -> Brand13 -> Bootx64.efi.
    warning machine is not in committed state.
    Similar Threads - Warning machine committed Forum Date
    HP-Compaq Still Warning machine is not in committed state BIOS/UEFI Jan 14, 2018
    Kinh nghiệm WARNING !!!! MSI MS-16P11 LCD 40 PIN 120HZ 3D 17.3" Computer Hardware Repair Jun 25, 2019
    HOW TO REMOVE ERROR machine is not in committed state HP 450 G2 BIOS/UEFI Jul 25, 2018
    BIOS PC ECS Z97-MACHINE BIOS/UEFI Jul 12, 2018
    M30-70 Laptop (Lenovo) Machine Type 80H8 BIOS/UEFI Dec 27, 2017
  3. marwinbosst
    marwinbosst New Member
    BIOS issues after motherboard swap on a HP Elitebook 8560w
    Since I have exhausted all possible ways on the internet to solve this issue, I thought to give it one last try and publish it here – maybe an expert can suggest a solution.
    Preamble:
    I probably fried my old motherboard with a bad power-connector, so I decided to get a new one. The old motherboard was built for a dual core CPU, but since I found a cheap, new motherboard with quadcore CPU and since on the HP forurms I read it was possible to upgrade from a dual core mother board to a quadcore motherboard ( 684319-001 ), I decided to upgrade the motherboard and also get a new used (quadcore) i7 2760QM. Replacing the motherboard went rather smooth, I only realised that the LCD cable was damaged (it was giving black screen), so I had to replace that as well.
    Symptoms:
    Having replaced the motherboard, I started getting the message “Warning – machine not in committed state”, but after a split second Windows 10 boots normally (I actually was surprised I didn’t have to reinstall the OS). Furthermore, when I unplug the laptop from the power cord, the screen starts flickering before turning off, but the machine keeps running. The screen also turns off when unplugging the power while in BIOS, so I guess it is not an issue linked to power plans and other Windows stuff.
    Things I’ve tried:
    I thought the best thing is to leave aside the power issue for now and solve first the software issue hoping that it would also be responsible for the power issue.
    First I successfully updated the BIOS to the last available version, F.60.
    Then, to get rid of the BIOS error message my first approach was to use the AMTool from ( www.compit.se/?p=206 ), even though I used the HPUSBFW tool to generate a DOS bootable USB stick instead of virtual floppy drive, which won’t run on x64 machines.
    When I read the AMT, I get
    VPro uncommitted
    Descriptor unlocked
    Management Engine enabled
    Flash protection override disabled
    Which is regular, except for the Management Engine, which in theory should be disabled. On the attempt to shutoff or turn on the ATM I get the error
    Vpro Configuration not supported (Write) Error level == 7
    I checked on the Intel website whether the CPU, has VPro (it has). I also unplugged the MB battery (coin battery) from the motherboard in hope it would reset the VPro as I bought a used CPU, but it didn’t help.
    My next guess was that the AMTool won’t work on an unbranded motherboard, so I tried various versions of NBDIMIFIT (from, for example ftp://ftp.grouped-tech.com/Applications/HP%20Tools/ ), but when trying to save P/N(Sku), model name etc., the outcome is always
    Failed to write SKU number.
    Failed to write model name.
    After that the NBDIMIFIT.bat prompts me to prepare a FAT32 USB stick with the content of Brand11 in it, enable UEFI boot mode and boot from the efi file bootx64.efi. But this doesn’t work either – the machine won’t boot and show a black screen with white cursor (not blinking), so I guess it freezes. I tried different .efi files but with no success. I even tried a windows bootx64.efi file to see if there is a problem with the uefi boot in general, but with no success, the error being that some booting info is missing due to recent hardware changes.
    These are all possible approaches to the problem I’ve found. Just to recap, the motherboard is new (not used) while the cpu is a used one. For now, unless there is no saint out there with a solution to the problem, I’ll ignore the “not in committed state” warning, hoping it won’t cause issues further down the road and get a new battery in hope it will solve the power issue. Any advice is greatly appreciated of course.
  4. ss lee
    ss lee New Member
    Only the message that the files are not working appears.
    brand11, brand12, brand13 not working....
      125.3 KB
      3
      105.4 KB
      2
      119.7 KB
      2
    send i bios old error & model, motherboard code ?
  6. ss lee
    ss lee New Member
    old bios is burn,
  8. 05ifix
    05ifix Moderator
    I need a help for this bios
    i try with this metod but no result.
    SN 5CG50303WQ
    MAc Adress D0BF9CDF9155
    UUID A9F6BBFF-1DF5-11E4-8402-B24C3C03C0FF
    PCID A3009F410303
    product L3V91EC#ABY
    #7 05ifix, Feb 21, 2017
    Want to fix by hand you need to send my old bios file
  10. 05ifix
    05ifix Moderator
    I dont have old bios, the laptop comes in service with dumps from internet.
    Now the laptop logo appers quick , all drivers are installed, but receive this error at start up. I want to remove error
  12. 05ifix
    05ifix Moderator
    Ok , but witch one from link , is so many
  13. 05ifix
    05ifix Moderator
    Still not fix the problem , receiving error MPM is not unlocked. Will not be able to set bios settings , please escalade with UUID to get SMC blob to unlock MPM .
  14. mila12
    mila12 Well-Known Member
    Hello
    Can we change the UUID and Serial Number in the SMC.bin file?
    Regards
  16. mila12
  18. mila12
    • SMC.bin
      868 bytes
      74
    All info have in file bios 8MB or 16MB (PCH)...
    You do not understand what I say ?
  20. mila12
    This file was created by hp.
    The UUID and serial numbers in the file can be changed and the serial numbers in the notebooks are reset.
    With Win + down + up key combination
    nepolean likes this.
  21. bangbang
    bangbang Well-Known Member
    Đã làm 3 cách này mà vẫn còn nổi dòng chữ đỏ ad ơi, máy zbook 15 bị pass bios, chép bios clear me của a vô ok, nhưng nổi dòng chữ đỏ Machine is not.....
