Laptop HP BIOS
Discussion in 'BIOS/UEFI' started by technical, Jul 16, 2015.
  1. dimpu
    dimpu Well-Known Member
    How to remove password BIOS UEFI HP EliteBook & EliteBook
    HP BIOS Unlock [FOR DOS]
    Well after some small delay, it's here. This is the successor to my Windows based solution (Original Thread) to reset HP Pro/Elitebook BIOS Passwords. I have tried to make this as simple as possible. So here is what my package HPBR.RAR contains.
    It contains a folder with utility to back up and re-image a usb thumb drive.
    It contains an image (HPBR.IMG) of my usb thumb drive.
    My image was made from a 64MB drive, but it compressed super awesome, so now the rar package is ~500KB. Your thumb drive needs to be 64MB or larger! After it is imaged, it will become 64MB in capacity (IE: a 1GB Drive will become 64MB), and may require Linux DD to restore true capacity, but that's outside the scope of this tool, I say it more for informational purposes. I have support for these 22 models. A supported model does not guarantee compatibility however. If you receive a 'Model not supported' error, please PM me with the error code number.
    [SUPPORTED MODELS]
    Elitebook 4310s Elitebook 2530p, Elitebook 4510s, Elitebook 6930p, Elitebook 8530w, Elitebook 8460p, Probook, 6550b, Probook 6535b, Probook 6730b, Probook 6735b, Probook 6460b, Probook 8730w, Probook 2230s, Probook 2560p, Probook 6455b, Probook 8560p, Probook 2730p Probook 8440p, Probook 8530p, Probook 8540w, Probook 2740p, Probook 8560w
    [USE]
    Once your thumbdrive has been imaged with HPBR.IMG, boot your HP Probook/Elitebook with the USB Thumbdrive. You will be presented with a menu:
    HP PRO/ELITEBOOK BIOS PASSWORD RESET
    (c)2014 Mazzif
    PLEASE TELL ME YOUR MENU CHOICE
    1] FIRST RUN? 4] ABOUT
    2] SECOND RUN? 5] SHOTGUN
    3] RE-PROGRAM 6] EXIT
    Selection number:
    The options are mostly self explanatory.
    1] If first time using the tool, use this. Some models require a second run, and it will tell you if you need to run again. If so, then choose '2'
    2] If program instructs you to reboot and run again
    3] If you receive a white screen during POST about missing or invalid system board information, use this option to reprogram your board. It may ask for Serial Number, Part Number (SKU), Asset Tag number, or ConfigurationID (If asked for Config ID, use 25 0's (Twenty-Five Zeros)
    4] About my work
    5] SHOTGUN
    Runs all keys. Good for testing models not on the list.
    6] EXIT
    Quit clean
    Option 1 brings up a second menu where you then select your model:
    HP PRO/ELITEBOOK FIRST RUN
    1 Probook 6550b 12 Elitebook 4310s
    2 Elitebook 2530p 13 Elitebook 4510s
    3 Elitebook 6930p 14 Probook 6535b
    4 Elitebook 8530w 15 Probook 6730b
    5 Elitebook 8460p 16 Probook 6735b
    6 Probook 6460b 17 Probook 8730w
    7 Probook 2230s 18 Probook 2560p
    8 Probook 6455b 19 Probook 8560p
    9 Probook 2730p 20 Probook 8440p
    10 Probook 8530p 21 Probook 8540w
    11 Probook 2740p 22 Probook 8560w
    Selection number:
    Select the number that corresponds to your model and press Enter. The system will do the rest.
    If prompted to run a 2nd time, boot to thumbdrive again, this time choosing option 2, and press enter. Again, you will have a model selection choice. Select the number that corresponds to your model again, and press Enter.
    I don't know what else to say here. This is my first C program I've ever written, so there may be some unforeseen bugs. My final line count was 1162 lines of C. I used Open Watcom C v2 Compiler. So far I have been the only person to test, and I don't have all 22 models on hand, but 11 of the 22 I did, so I did physically test those, and they all worked awesome. If you hit a bug or snag, sorry, let me know and ill fix it.
    I hope you find my work useful.
  2. CHADI BDEWI
    CHADI BDEWI Well-Known Member
    hello hp dv5-1041et bios
    Search via motherboard code :p
    or
    Use
    BID3602 F21
    BIDD3603 F21
  4. CHADI BDEWI
    hello
    HP G62 PM_A_HPC_S MV_MB_V4 bios
  6. CHADI BDEWI
  8. vphuoccntt
    vphuoccntt New Member
    Cho mình xin file BIOS HP Probook 650 G1
    HP Probook 650 G1 - 6050A2566301-MB-A04
    Chip Bios: Winbond 25Q128FVSQ 1452
    Current System BIOS Version: L77 Ver. 01.31
    File Bios đính kèm đang bị Lock pass Admin
    Mình có đính kèm trang infomation F1
    Có đây bạn
    https://vinafix.vn/threads/probook-650-6050a2566301.12463/
  10. vphuoccntt
    Nhưng khác cái 6050a2566301-MB-A02 của mình là MB-A04 có sao không?
    Do mình cũng down mấy bản kia không có DMI. down xong bị mất seri number - SUK number
    khởi động báo lỗi!
    Con đây là file bạn đính kèm mình đã unlock pass
  13. vphuoccntt
    bạn mở được rồi à! ok Thanks bạn! h nạp tiền để dowload hả bạn
  15. ads
    ads Well-Known Member
    bios hp 14-g006au mb LA-A997P REV 1.0
  16. ABDULLAH FALAH
    ABDULLAH FALAH New Member
    bios laptop acer ok ok
  17. serradell
    serradell New Member
    aqui os dejo el dump de la placa madre daoyobmb6co rev:c
    modelo muy nuevo en garantia aun
  18. serradell
    dump de polaca madre s050 la-a992pz
    • uc2.bin
      8 MB
      47
  19. vien
    vien Well-Known Member
    ad cho em con bios hp14-r220tu tk ad nhieu
Similar Threads - Laptop BIOS Forum Date
Yoga S730-13IWL Laptop (Lenovo) BIOS BIOS/UEFI May 28, 2019
Dell Vostro V13 Laptop BIOS Bin BIOS/UEFI Nov 16, 2018
ASUS Laptop X556UV BIOS BIOS/UEFI Aug 31, 2018
U41-70 Laptop (Lenovo) BIOS BIOS/UEFI Aug 30, 2018
