Asus X550VX
Discussion in 'Schematics' started by technical, Apr 19, 2016.
    yes, buy one VIP and get support
    Account Upgrades
  2. jasko_jacker_1
    jasko_jacker_1 New Member
    Someone can confirm that the "most of the LEDs are on without a bios post" is a problem of pch?
    There are many issues involved, Follow us the chipset bug is the most common.
  4. ajamin.ali
    ajamin.ali Well-Known Member
    i have asus k550vx and mainboard model is x550vx rev: 2.1
    its auto shutdown after 30 min
    please fix it
    try
  6. ajamin.ali
    sorry boss. it has same problem.
    check hardware you...
  8. ajamin.ali
    hardware cheked. all parts ok.
  9. rdumkin
    rdumkin New Member
    Hi! Can you help me please my Asus K550v mb x550vx rev 2.0 turns off every 30 min. 30 minutes work fine. I have replace Hub hm170. Here is the original dump
    try this
  11. rdumkin
    rdumkin New Member
    Not works No display.
    try bios on top ?
  13. rdumkin
    rdumkin New Member
    I tried this bios. Turns off after 30 min like original.
  14. rdumkin
    rdumkin New Member
    hi friend! Have you resolve the problem Asus 30 min turns off. I have the same problem after i change the HUB
    30 min is problem hardware not bios after where try same one problem. Please skip bios
  16. mouez_by
    mouez_by New Member
    did u fix your problem only with posted bios and without io update?!
    i have same issue no vcore voltage and all parts seems be ok
  17. Root
    if the full voltage may not need IO programming
    mouez_by likes this.
Similar Threads - Asus X550VX Forum Date
Asus A550VX X550VXK 2.0 BIOS/UEFI Feb 21, 2018
