ASUS VivoBook Max X541UV
Discussion in 'BIOS/UEFI' started by technical, Sep 5, 2016.
  1. CHADI BDEWI
    CHADI BDEWI Well-Known Member
    x541uvk 2.0 bios
    i5-7200 u
    same on top
  3. Rui Fortunato
    Rui Fortunato Well-Known Member
    Hi Luis, I need your help
    I checked that you already solved this ..."all the bios have at least delay of 20 seconds to show image"
    In my case the delay it was around 27 seconds. Main Board X541UV Rev 2.0.
    Wold you please inform me whow can I solve this problem?
    Thanks in advance
    send file bios i help
    Programming file clear me here
    https://vinafix.com/threads/asus-vivobook-max-x541uv.24181/
  6. Rui Fortunato
    Thank you... please check the bios file attached
  7. Rui Fortunato
  8. Rui Fortunato
    Now the delay is 13s
    Original bios error what? have save before yet
  10. laptopvn
    laptopvn Well-Known Member
    Nhờ AD clear me dùm
  12. shakeel
    shakeel Well-Known Member
    Asus x541uv disable ram onboard sir any chance
  14. shakeel
    sir you have conformed. I want to buy (Asus x541uv disable ram onboard )
  16. shakeel
    I have 15$ already pay by pay pal
  17. shakeel
    sir where is my file Asus x541uv disable ram onboard .
    Please check conversations
  19. laptoptpt
    laptoptpt Well-Known Member
    ad tai lieu dis ram onboard 15USD ah
    yes
Similar Threads - ASUS VivoBook X541UV Forum Date
ASUS VivoBook S15 S530FA BIOS BIOS/UEFI Aug 12, 2019
ASUS VivoBook 15 X540UV BIOS/UEFI Jun 14, 2019
ASUS VivoBook Flip 15 TP510UA BIOS BIOS/UEFI May 12, 2019
ASUS VivoBook Flip 14 TP401CA BIOS BIOS/UEFI May 12, 2019
ASUS VivoBook Flip 12 TP203NAH BIOS/UEFI May 12, 2019
