Kinh nghiệm WARNING !!!! MSI MS-16P11 LCD 40 PIN 120HZ 3D 17.3"
Discussion in 'Computer Hardware Repair' started by hgzy ahmd, Jun 25, 2019.
  1. hgzy ahmd
    hgzy ahmd Well-Known Member
    DEAR FRIENDS
    PAY ATTENTION WHEN YOU TRYING TO REPLACE NEW MODEL LCD 17.3 " 40 PIN MODEL " N173HHE G32 :
    NEW MODEL HAS THE SAME TRADITIONAL 40 PIN CONNECTOR BUT!!!!!
    OTHER PIN-OUT
    SOME ONE TRY TO REPLACE IT AND DAMAGE THE EC IO
    I REPLACE IO AND FORTNIGHTLY I FOUND IO FIRMWARE IN MSI DRIVERS IN FIRMWARE SECTION EC
    FIRMWARE
    • Wow Wow x 1
    Similar Threads - WARNING 16P11 120HZ Forum Date
    HP-Compaq Still Warning machine is not in committed state BIOS/UEFI Jan 14, 2018
    Warning!! - machine is not in committed state! Computer Hardware Repair Jun 29, 2016
    GE73VR 7RF RAIDER MS-17C11 MS-16P11 BIOS/UEFI Aug 5, 2019
  3. Rui Fortunato
    Rui Fortunato Well-Known Member
    Hello Thien,
    Can you clear the bios password from the next file pls
    try it or you need Programming ENE
  5. Rui Fortunato
    it worked thank you very much
