Swift acer SF114-31 (Inventec) Model MB-OXFORD-2
Discussion in 'Schematics' started by technical, May 28, 2017.
    MB-OXFORD-2 6050A2888301 A01
    BIOS O2105SFS
    #1 technical, May 28, 2017
    Similar Threads - Swift acer SF114 Forum Date
    Acer Swift SF514-52T N17W3 17809-1M BIOS/UEFI Apr 9, 2019
    Acer-Gateway Acer Swift 3 (HE4EA motherboard) need shcematic or board view Schematics Sep 30, 2018
    Acer Swift SF113-31 BIOS AS3EA_UMA REV 2.1 BIOS/UEFI May 28, 2017
    Acer Swift SF314-52G CA4DB_10L BIOS/UEFI May 28, 2017
    Acer Swift SF314-52 bios HE4EA REV 2.0 BIOS/UEFI May 28, 2017
    OXFORD2-6050A2888301-MB-A01.brd
    boardview
  4. 05ifix
    05ifix Moderator
    Schematic ?
    current Unavailable
  6. 05ifix
    05ifix Moderator
    It is on elvikom, but cannot download
    link?
  8. MissAircraft
    MissAircraft SUPER VIP
    i cant open the boardview its always gives me error
  9. MissAircraft
    I have that laptop and I have very weird problem. The keyboard doesn't work at all . I have replaced with new one but still the same . I have updated to latest bios and still the same . Could the Novoton IC will have to be replaced or reprogrammed?? Any help?
    NPCE985LB0DX non program
  11. MissAircraft
    i have replaced NPCE985LB1DX with new and the keyboard still doesnt work . well if you keep holding random keys together it sometimes respond and sometimes press random keys and sometimes 1 key stuck. keyboard is brand new as well. ANy suggestions what might me? keyboard line doesnt look that something is shorting and not touching other keyboards lines
    Check all connections from the motherboard with the keyboard
  13. MissAircraft
    i have check all connections and each of them connect directly to to NPCE985LB1DX. bios is latest. it doesnt work in bios mode as well as windows
  14. MissAircraft
    if you have pressed number 1+¬ together and then start pressing letters it respond and works but not numbers as soon as you let the 2 keys go then it doesnt respond at all
