Yoga 11e 5th Gen (Type 20LN 20LM) Laptop (ThinkPad) BIOS 17833-1M
Discussion in 'LENOVO' started by technical, Aug 28, 2018.
    BIOS r0tuj08ww
    ThinkPad 11e 5th Gen, Yoga 11e 5th Gen (Pentium/Celeron Processors)
    LLA-1, 17833-1M
  3. b norbu
    b norbu Well-Known Member
    Hi!
    do you have dump for this model? thnks!
    send old bios error and motherboard code i help.
  5. b norbu
    yoga 11e, 20LM-S00h00 old bios with bios password, motherboard code LLA-1, 17833-1M, 448.0DA05.001M
    Thanks a lot!
    bios update on top.
  7. b norbu
    I tried , but I don't have image :( , do you have any other idea ? thank you!
    you sure bios you send have display ? can send one photo
  9. b norbu
    yes, absolutely. I tested again, with the original dump is working, but is with password
    thank you!
    i see you can login cmos and window ? laptop not request enter password ?
    think it is normal
  11. b norbu
      261.5 KB
    yes, where login CMOS you can disable password ?
  13. b norbu
    no, is it not possible to make any security changes , there are inactive...
    It is very difficult for me to suspect that you need to check for KBC with or no programming
  15. b norbu
    thank you for your help! it was very useful! thanks again!!!
    try again bios this
  17. b norbu
    it is worse, i have image, but i can not enter in bios, thare is a password the system is shutting down. i thing I will use the original, because whit that i can use a windows system. thanks for your effort again!!!
  18. levi
    levi Well-Known Member
    Can i get EC bios for this bios.
    it use ec name ? send old i help build.
  20. levi
    my EC was burnt. EC name is NPCE288GA0DX
