Asus ROG GL502VS BIOS GL502VS.302 6th HM170 Processor Intel® Core™ i7 6700HQ Processor, Operating System Windows 10 Home Windows 10 Pro Chipset Intel® HM170 Chipset Memory DDR4 2133MHz SDRAM, 2 x SO-DIMM socket for expansion, up to 32 GB SDRAM Display 15.6" (16:9) LED backlit UHD (3840x2160) 60Hz Anit-Glaire Panel with 72% NTSC with G-Sync 15.6" (16:9) LED backlit FHD (1920x1080) 60Hz Anit-Glaire Panel with 72% NTSC with G-Sync With WideView Technology Graphic NVIDIA GeForce GTX 1070 , with GDDR54GB/8GB VRAM Storage Hard Drives: 1TB 5400RPM SATA HDD 1TB 7200RPM SATA HDD Solid State Drives: 128GB/256GB/512GB SATA3 SSD Solid State Drives: 256GB/512GB PCIE Gen3X4 SSD Keyboard Illuminated Chiclet Keyboard Card Reader Multi-format card reader (SDHC/SDXC/MMC) WebCam HD Web Camera Networking Wi-Fi Integrated 802.11b/g/n Integrated 802.11 AC Bluetooth Built-in Bluetooth V4.0 Interface 1 x Microphone-in/Headphone-out jack 1 x USB 3.1 TYPE C port(s) 3 x USB 3.0 port(s) 1 x RJ45 LAN Jack for LAN insert 1 x HDMI 1 x mini Display Port 1 x SD card reader 1X AC adapter plug Audio Support Windows 10 Cortana with Voice ASUS SonicMaster Technology Battery 4 Cells 62 mAh Whrs Battery Power Adapter Plug Type :ø5.5 (mm) Output : 19 V DC, A, 180 W Input : 100 -240 V AC, 50/60 Hz universal Dimensions Tablet: 390 x 266 x 30.1 cm (WxDxH) Weight Tablet: 2.34 kg with Battery Security Kensington lock BIOS Booting User Password Protection HDD User Password Protection and Security Certificates UL, TUV, CE Marking Compliance, FCC Compliance, BSMI, Australia C-TICK / NZ A-Tick Compliance, CCC, GOST-R, CB, Energy star, WEEE, RoHS Manufacturer Warranty 1-year limited International hardware warranty. *different by country
[QUOTE = "ThienBui, post: 55928, membro: 6"] Você precisa enviar bios de arquivo antigo. [/ QUOTE] ????
[QUOTE = "Leandro Werner Hoyer, post: 62757, member: 47902"] [QUOTE = "ThienBui, post: 55928, membro: 6"] Você precisa enviar bios de arquivo antigo. [/ QUOTE] ????[/CITAR]
