Apple APPLE A1286 820-2915-B
Discussion in 'BIOS/UEFI' started by technical, May 31, 2014.
  1. Khalidna
    Khalidna Well-Known Member
    palease remove the password
  3. 05ifix
    05ifix Moderator
    Could you check this.
    No internal video, external is ok.
    And clean me if possible?
    Thank You Sir
  5. 05ifix
    05ifix Moderator
    Thank You!
    Very Appreciated!
  6. lifestone
    lifestone Well-Known Member
    FILE IS LOCKED,
    unpas.bin
  8. lifestone
    usb ports not working after i programmed the unpass bios, trying to install os.
    not sure problem form bios unpasss.
    try it
  10. lifestone
    no display, no chime after flashing @820-2915-B_build.bin file
  11. K-PAX
    K-PAX Well-Known Member
    the better solution is disable gpu,is forever
  12. cristianfga
    cristianfga New Member
    ayudame quitando la llave gracias
    unlock1.bin
Similar Threads - APPLE A1286 2915 Forum Date
Apple APPLE K91F K91X FLYING_DUTCHMAN 051-8620 820-2915 Macbook Pro A1286 Schematics Jul 6, 2014
APPLE A1286 MLB 820-2850-A BIOS/UEFI Oct 18, 2016
Apple Apple A1286 J31 051-9585 820-3330-B Schematics Jul 6, 2014
Apple APPLE K19 MLB 051-7892 A1280 A1286 820-2523-B A1287 Schematics Jul 6, 2014
Apple APPLE K18 MLB 051-8504 820-2850 051-7546 820-2330 A1286 Schematics Jul 6, 2014
