Asus X555LD 2.0 60NB0640-MB1340
Discussion in 'BIOS/UEFI' started by technical, Jan 21, 2015.
  1. 02ifix
  2. JOSCOM
    JOSCOM New Member
    hi whit out program use to file ? thanks
  3. settv2011
    settv2011 Well-Known Member
    ad cho em xin bios ite it8585 x555ld rev 2.0 voi ak
  5. daniel suler
    daniel suler New Member
    hi, good morning someone have bios dump to x555ld ver 2.0 to write with the svod?.. only find de dump to ver3.6 and 3.3 helpme please. thanks a lot
    same version, Programming and send me result
  7. Bogaphonic
    Bogaphonic New Member
    Hello. I've got some problems with an x555ld, i get no display or hdd led, only power led and fan spins. What may be the fix for this issue ? Thank you
    Buy one VIP and get support
    Account Upgrades
  9. Dima1974
    Dima1974 New Member
    Hi! :) if you need disabling integrated ram you can try to disabling smbus manager line sda scl from ram to I2C to systemboard. I wish you success!
    Account Upgrades
  11. ROBOTINCR
    ROBOTINCR Well-Known Member
    Hello, I need bios and EC for this card: X555LD REV.2.0 PN:60NB0650 - MB1810 CPU: i3 VIDEO CARD NO PRESENT.everything is detected well, but when it turns on, it stays only in bios setup, thanks for your help.
  13. umairjaffar
    umairjaffar New Member
    I have 555LD rev 2.0 motherboard with Nvidia gpu, Core i7 4510u.
    But motherboard PN:60NB0620-MB1802 is different from your model.
    Will X555LD lx-4xxxxU ECROM.bin work on my motherboard?
    this not is number it only is number product. not care it.
    code right is X555LD rev 2.0
    Nomi929 likes this.
  15. 07ifix
    07ifix Moderator
    la-f952p bios need
  16. 07ifix
    07ifix Moderator
    acer laptop
  18. Hesley
    Hesley New Member
    @ThienBui Is there a boardview for the X555LD Rev 3.6 ? Or is it the same as Rev 3.3
  20. Hesley
    Hesley New Member
    @ThienBui Sorry overlooked it... Thank you very much for your outstanding help&service. :)
Similar Threads - X555LD 60NB0640 MB1340 Forum Date
Asus X555LD 2.0 BIOS/UEFI Jun 10, 2019
bios asus x554l board x555ld rev 3.3 sticker x555lab bios chip mxic ite 8585e fxa BIOS/UEFI May 17, 2017
PCB ASUS X555LD Rev 2.0 60NB0620 MB1911 BIOS/UEFI May 15, 2017
ASUS VM510LJ X555LD MAIN BORAD REV 3.6 BIOS/UEFI Apr 22, 2017
Asus Asus X555LD_2.0 BoardViewer(FZ) Schematics Jan 5, 2017
