Toshiba Unlock/Remove Bios Password Toshiba With Response Code
Discussion in 'BIOS/UEFI' started by 21ifix, Aug 21, 2017.
  1. biosunlocker
    biosunlocker New Member
    Follow this procedure to delete a BIOS password using the Response Code method .
    MY Telegram : @biosunlocker
    Notice: HAISUNG4344 or vnn567 is advertising with my picture, he doesn´t own generator and cant calculate the response code
    tecra-z40-a1401-600-09.
    >>> Be sure to keep the computer powered-on during this entire procedure. The Challenge Code issued by the BIOS is only valid until the computer is turned off and back on. <<<
    1. At the BIOS password prompt ("PASSWORD = "), press and release the following keys, one after another: Ctrl, Tab, Ctrl, Enter
    The computer's response should be:
    PC Serial No.= XXXXXXXXX
    Challenge Code=XXXXX XXXXX XXXXX XXXXX XXXXX
    Response Code=
    2. CHALLENGE CODE SCREEN:
    3. Enter the Response Code at the "Response Code=" prompt, and press Enter.
    The Response Code correct your Laptop will shown the image below :
    4. Press the F2 key.
    The BIOS / CMOS Setup screen should appear. Follow these steps to de-register the password:
    1. Press 'P' to jump to the Password field. "Registered" will be highlighted.
    2. Press the spacebar to change "Password= Registered" to "Password= ".
    3. Press the spacebar and press Enter. The BIOS should respond with "New Password = ".
    4. Press Enter again. The BIOS should respond with "Verify Password= ".
    5. Press Enter again. The BIOS should respond with "Password= Not Registered".
    6. Press the End key. The BIOS should respond with "Are You Sure?".
    7. Press Y.
    The computer will restart, and load Windows, without requesting a password.
    Professional Unlock Thinkpad ibm and Toshiba ..ect.., My telegram : @biosunlocker
    dang bios password new. [/QUOTE]
  2. 23ifix
    23ifix Moderator
    [/QUOTE]
    you are so wrong man , VNN can unlock all laptop models , thinkpad , toshiba, panasonic , surface , ...etc
    he is profesional 100% , i worked with him since i started , he unlocked all requested laptops , and all toshiba models , he is also well know on internet ! don't use his name to get some costumers , that's shame on you , i hope you realise what you are doing , and i hope also that you can unlock by yourself not by someone else , because people like you can't do anything by their own
    21ifix and 03ifix like this.
  3. 03ifix
    I agree 100% @hakim comment.
    21ifix likes this.
  4. 21ifix
    21ifix Moderator
  5. biosunlocker
    It dosnt matter for me if u have solutions or not, JUST USE UR PICTURES, the ones u r using are for my client !!!!!!!!
  6. biosunlocker
    he is profesional 100% , i worked with him since i started , he unlocked all requested laptops , and all toshiba models , he is also well know on internet ! don't use his name to get some costumers , that's shame on you , i hope you realise what you are doing , and i hope also that you can unlock by yourself not by someone else , because people like you can't do anything by their own[/QUOTE]
    U even dont know me, or did a contact, so how u can use my name?
  7. 21ifix
    21ifix Moderator
    - I can use any picture which don't copyright registration (you can angry , i don't care ) it don't violate rules of forum
    - you are dirty play when sent many spam in my topic , your purpose to get some costumers.
    @biosunlocker Let's compete fairly , Don't play childish games
    #27 21ifix, Apr 22, 2019
    03ifix likes this.
  8. 23ifix
    23ifix Moderator
    you're welcome , i don't know you , and i don't need to know you , because you hurt other people and use other names to get their clients and it is very shamefull , VNN maybe used you're picture but not you're solution , he always find solutions and work , and he is very very professional like i said before , but you ! you don't seem to be pro because you posted this and playing chlidish game , and crying about a picture ! if he stole your solution you would be right , but it is just a picture , but you said he wrong things about the man , and that's not good at all , if i were you i would be sorry not talk again like this
    21ifix likes this.
  9. 23ifix
    23ifix Moderator
    and
    U even dont know me, or did a contact, so how u can use my name?[/QUOTE]
    stop trying to be like a superstar !! no one knows you , you are anonymous ! i don't need to know people like that in my life , you need to be right to all peoples my friend
    21ifix likes this.
  10. 18ifix
    18ifix Moderator
    it easy to unlock toshiba it old method to create generator ...
  11. biosunlocker
    AMOUN slave !!
  12. 23ifix
    23ifix Moderator
    go find to your self a solution ! you only need to think ! everybody is bad and you are the greatest right !
    03ifix and 21ifix like this.
Similar Threads - Unlock Remove Bios Forum Date
BIOS PC Inspiron 537s Unlocked BIOS ( G41T-DM ) AHCI BIOS/UEFI Jun 29, 2021
macbook pro A1425 efi password unlock plz BIOS/UEFI Jul 8, 2019
harddrive unlock Computer Hardware Repair Jul 6, 2019
HP-Compaq i need unlock bios hp elitebook 840 G3 BIOS/UEFI Apr 30, 2019
Dell Unlock System Number XXXXXXX-0001 BIOS 32MB Computer Hardware Repair Apr 9, 2019
